Delayed Output Off
Delayed Output Off
Postby matt_b » Wed Jul 21, 2021 12:11 am
This is my first post, so hello - I'm currently in the process of rewiring the control cabinet for my CNC router and changing its controller for an AXBB-E. Is it possible to configure a spare output, on the AXBB-E, so that it activates whenever either of the M3/M4 pins are active and then deactivates a configurable number of seconds after the M3 or M4 pins have become inactive?
Matt.
matt_b
Re: Delayed Output Off
Postby cncdrive » Wed Jul 21, 2021 2:28 pm
Yes, it is possible with a Macroloop. The loop has to check the M3 and M4 LEDs.
Dezsoe could probably help you with writting a macro quickly.
Postby matt_b » Thu Jul 22, 2021 10:41 am
Thanks - I'll look into that.
matt_b
Postby dezsoe » Sun Jul 25, 2021 10:09 pm
Hi Matt,
Save the following code to a macro and set it as a macroloop. Change the time constant and the output port/pin/active low as you need.
// Set output if spindle is on and turn it off delayed
bool Spindle = exec.GetLED(50) || exec.GetLED(51);
if (Spindle != lastSpindle)
  if (Spindle)
    // Spindle was turned on -> turn on output
    turnOn();
  else
    // Spindle was turned off -> reset timer
    count50ms = 0;
  lastSpindle = Spindle;
if (count50ms < offTime)
  // Timer is running
  if (++count50ms == offTime)
    // offTiem is reached -> turn off output
    turnOff();
// =============================================================================  -- Events --
#Events
// =============== Time constant in 1/20 seconds (20 = 1s)
const int offTime = 20;
// =============== Output port, pin, active low
const int port = 3;
const int pin = 17;
const bool alow = false;
// =============== Variables
static int count50ms = offTime;
static bool lastSpindle = true;
// output functions
// =============== Turn on output
void turnOn()
  if (alow)
    exec.Clroutpin(port, pin);
  else
    exec.Setoutpin(port, pin);
// =============== Turn off output
void turnOff()
  if (alow)
  else
