New user setting up profile, can't save changes
Postby jimmuncy » Fri Jun 25, 2021 5:41 pm
Hello
I just installed my UCCNC and now am setting it up to work with my MPCNC machine. I am frustrated trying to save configuration settings. If I calibrate the Axes it will save the calibrated units per step but if I change any other nubers on that screen and hit Apply or Save the numbers immediately change the values back to what they were. I have tried running the program with Admin privileges, turning off the antivirus program, Copying the profile and everything but it still will not save my setting. What am I missing? :cry:
jimmuncy
Re: New user setting up profile, can't save changes
Postby ger21 » Fri Jun 25, 2021 7:15 pm
Hit the ENTER key after entering numbers.
There's also a setting on the Appearance tab to disable the ENTER key requirement.
Postby jimmuncy » Sat Jun 26, 2021 2:05 am
OK, thanks! The enter key was not working but when I unchecked the setting to "Validate textfields with with Enter Key only" then the save button works fine.
jimmuncy
