Screen editor not saving in demo mode?
Postby A_Camera » Fri Dec 30, 2016 5:36 pm
I am on a trip without a CNC and planned to work on some macros and screen changes when I have some time in the hotel room, but when I make changes those are not saved, so the next time I start UCCNC up, the changes are not visible.
Is this normal? I thought only the motion is prevented in demo mode.
Re: Screen editor not saving in demo mode?
Postby ger21 » Fri Dec 30, 2016 6:02 pm
No, I designed an entire screen in demo mode. Make sure that your saving the correct screen.
Postby A_Camera » Fri Dec 30, 2016 6:08 pm
ger21 wrote:No, I designed an entire screen in demo mode. Make sure that your saving the correct screen.
What do you mean? Isn't the opened screen the correct screen? ...and isn't it saved automatically when you exit the editor?
Postby ger21 » Fri Dec 30, 2016 6:20 pm
No, it's not saved automatically. You have to save it, from the last tab (or second to last) I think in the editor.
You are correct, though, in that it can't be the wrong screen. :oops:
Postby cncdrive » Fri Dec 30, 2016 6:35 pm
To save the screenset you have to press the Save screenset button on the Screen editor on the File tab page.
Postby A_Camera » Fri Dec 30, 2016 10:37 pm
Thank you both. I thought I tried every Save and Apply I could find. In the end, I copied and renamed the default screen set and saved changes in that, also renamed the screen set name in the configuration file from the default to the new one and that seems to have solved it.
Users browsing this forum: No registered users and 36 guests
