UC300eth-5lpt 12V output for fan ?
Postby alex_s » Fri Dec 30, 2016 5:09 pm
can i use the analog 12V output to drive a fan ?
br
Alex
alex_s
Re: UC300eth-5lpt 12V output for fan ?
Postby cncdrive » Fri Dec 30, 2016 6:46 pm
Controlling a fan directly with the analog output will not work, because the output is an opamp with limited current capability,
if I remember correctly it can supply upto 50mAmps per channel which is not likely to be enough for even a small fan.
Also the step up converter has a limited current capability, it has the current limit set to 100mAmps.
You could drive a transistor with it though and use an external 12V power supply if the fan is rated to 12V,
or use a 5V rated fan if you want to use the same PSU which supplies your UC300ETH.
Or you could drive an NPN transistor or N-mosfet with a digital output PWM.
Postby alex_s » Fri Dec 30, 2016 7:38 pm
Thanks for the answer the Amps are indeed to low, will use a step up on the 5V Supply i have its 6AMPs so it should have enough room to spare to power 2 case fans for the enclosure ;)
alex_s
