Huge file stalls UCCNC
Postby Pilsbury » Thu Apr 08, 2021 7:40 pm
Hi
I’ve been using UCCNC flawlessly for a while making 3 hour cuts with ease (several hundred thousand lines of G Code).
I am trying to load a massive project that my Aspire program suggests will take 72 hours to cut. So I’m guessing many millions of lines.
I created the file and code on my home PC (i7 16gb ram) and this took a while to process.
My PC connected to my CNC and running UCCNC is considerably older (intel core2 duo, 4gb ram 64bit) and takes the best part of an hour to load the file and then for the last 4 hours is pretty much stalled alternating between not responding and not being able to be used.
Would someone point me in the right direction as to how to rectify? I’m assuming it may well be my PC. If so, what would be a decent spec that could deal with this sort of very large file?
Help appreciated.
Pilsbury
Re: Huge file stalls UCCNC
Postby ger21 » Thu Apr 08, 2021 8:35 pm
What version of UCCNC are yo using?
Postby Pilsbury » Fri Apr 09, 2021 3:37 pm
Using 1.2111 - latest version
I have however solved my problem. It was an underpowered PC. My i7 16gb ram has now moved home to my workshop and loaded the file in 20 seconds. Cutting as we speak.
Pilsbury
Users browsing this forum: Baidu [Spider], Bing [Bot] and 38 guests
