Hope someone can point me to a solution. I'm baffled.
Home built CNC machine
UCCNC software
UC300eth board
Basic BO board (two actually)
After not running my machine for the last couple of days, I went out this morning and found out the axix (all three) would not run in the + direction. They will run in the - direction but when I try to go + they will not move. Also I found my A axis (slaved to Y) was not turning at all. I replaced the driver on A with a spare I had and then it operated ok, except for the no movement in + direction.
Checked all the wiring. All seem tight. Exchanged the BO board with anther spare I had and no change. Switched from port 2 to 3, changed all the settings and still no change.
I'm stumped. Any ideas?
