Machine jerks in curves and corners
Postby dynaflux » Fri Feb 05, 2021 10:20 am
I have rebuilt an Omio X8-2200L-USB with a AXBB-E and UCCNC, however the machine jerks in curves and corners - has anyone encountered this problem and have a solution? I have tried some different settings but without improvement.
dynaflux
Re: Machine jerks in curves and corners
Postby ger21 » Fri Feb 05, 2021 12:47 pm
What are your CV settings? Increase the error tolerances.
Postby dynaflux » Mon Feb 08, 2021 3:45 pm
I should mention those settings are imported from a XML Mach 3 - where it worked fine.
Comm. buffer size: 0.1
Constant velocity mode
Stop at angle degrees > 89
Look ahead lines count: 300
Lines error max: 0.03
Linear addition lenght max: 2
Corner error max. 0.03
Arc radius tolerance 0.1
dynaflux
Postby ger21 » Mon Feb 08, 2021 3:57 pm
Mach3 does not have most of UCCNC's CV settings, so they don't import.
Try increasing the two error max settings from .03 to 0.1.
Postby dynaflux » Mon Feb 08, 2021 4:12 pm
Ok. Tried to change the values but couldn't see any significant change. Any other suggestions on improved settings?
dynaflux
Users browsing this forum: Bing [Bot] and 22 guests
