Postprocessor for SimplexCam 4.1 or Ecam V4
Postby jef.maas@telenet.be » Wed Feb 03, 2021 2:27 pm
Have always worked with Mach3, in collaboration with Ecam V4 (SimplexCAM 4.1). I was able to enter a mach3 milling and turning postprocessor. Are there prostprocessors for UCCNC for that software? Sorry for poor English. (my language is DUTCH)
jef.maas@telenet.be
Re: Postprocessor for SimplexCam 4.1 or Ecam V4
Postby cncdrive » Thu Feb 04, 2021 3:18 am
UCCNC understands the same G/M codes as Mach3, so if your codes worked with Mach3 then it should also work with UCCNC.
Some fine adjustment of the post processor might be required, but usually an offshelf Mach3 post processor works just fine without modification.
Postby jef.maas@telenet.be » Fri Feb 05, 2021 10:50 am
Dear,
I have found the problem. The g code file that the program Ecam (Simplexcam) creates contains empty g code lines for a nice overview. When I run the program in Mach3, there is no problem. Your program doesn't seem to allow empty command lines in g code? Do you know a solution for this?
Thanks, Jef
jef.maas@telenet.be
Postby dezsoe » Fri Feb 05, 2021 1:09 pm
Can you post a non-working g-code?
Postby ger21 » Fri Feb 05, 2021 2:39 pm
What are empty g-code lines?
Blank lines are not a problem.
Postby jef.maas@telenet.be » Fri Feb 05, 2021 3:26 pm
An empty line was, for example, line N0006.
I modified the postprocessor so that it does not give line numbers without text.
Now UCCNC will accept the code.
N0002 (CREATED 02/05/2021 16:23:17)
N0003 (# 5 - CENTER DRILL D 1MM)
N0004 G0 G90 G94 G40 G49 G17 G21
N0005 (T5 CENTER DRILL D 1MM)
N0006
N0007 (CENTER DRILL D 1MM)
N0008 T5M6
N0009 G95
N0010 S4000 M3
N0011 M8
N0012 G0 X56.134 Y91.346
N0013 G43 H5
N0014 Z100.000
N0015 Z10.000
N0016 G81 Z0.000 R2.000P500 F0.015
N0017 X56.050 Y68.370
N0018 X55.915 Y45. 455
N0019 X55.830 Y22.479
N0020 X91.320 Y30.576
jef.maas@telenet.be
Postby ger21 » Fri Feb 05, 2021 4:08 pm
There is a setting in UCCNC to ignore unknown g-codes. Select that option.
Postby jef.maas@telenet.be » Fri Feb 05, 2021 10:01 pm
Bedankt Gerry.
jef.maas@telenet.be
