config the uc400eth
config the uc400eth
Postby alfre » Thu Dec 15, 2016 2:56 pm
Hi, I'm new user and I have buy a uc400eth controller. My problem is that I can not create communication between controller and PC via LAN despite having followed the procedures indicated in the manual. By running the utility program gives me this answer: IP range or netmask is wrong, UC400 IP address 10.10.10.11 NetMask 255.255.255.0 Interface number1 IP address 169.254.230.54 NetMask 255.255.0.0 . And there is no way to solve.
Please if you can help me thanx!!
alfre
Re: config the uc400eth
Postby cncdrive » Thu Dec 15, 2016 3:56 pm
If the IP address on your PC network card is 169.254.230.54 then it does not fit the UC400ETH's 10.10.10.11 IP setting.
Please read the UC400ETH user's manual: http://cncdrive.com/MC/UC400ETH%20datas ... manual.pdf
There is a step by step procedure description about how to setup the network card on the PC side.
Postby alfre » Sun Dec 18, 2016 7:55 pm
ok thanx, I've solved!! ;) :D
alfre
