disable limit switch
Postby BJB » Tue Dec 15, 2020 1:28 pm
Wonder if anyone can help me.
I have zeroed my cutter on the workpiece, but when i click on start cycle, because the piece is thick the spindle goes up on the "Z" and hits the limit switch. I need to know how to start the cycle if possible without the need for "Z" to go all the way up first.
Many thanks
BJB
Re: disable limit switch
Postby ger21 » Tue Dec 15, 2020 4:58 pm
Probably a setting in your CAM software.
Postby BJB » Tue Dec 15, 2020 5:23 pm
Dont think so, i'm using Aspire.
Do you know where i can change the limit switch settings?
BJB
Postby Soler » Tue Dec 15, 2020 7:59 pm
can you post your gcode
Soler
Postby thegreatwaldo » Tue Dec 15, 2020 10:56 pm
Check your rapid z setting in the toolpath material setting box. If you have it set to high the z axis goes up till it's out of space looses steps and then does horrible things. Don't ask me how I found out !!
Cheers
Andrew
thegreatwaldo
Postby ger21 » Wed Dec 16, 2020 3:49 am
Yes, check the Z settings at the bottom of the Material Setup.
Postby BJB » Wed Dec 16, 2020 5:57 am
Thank you for the advise will check it out later today.
BJB
Postby BJB » Wed Dec 16, 2020 1:41 pm
Thank you, you were correct it was the Z settings in material setup.
All sorted job cut.
Thanks for your help
BJB
Users browsing this forum: No registered users and 45 guests
