A_Camera wrote:CT63, feed rate I understand, but not spindle speed. Remember that the machines using UCCNC can run using imperial units as well, and some times you might need to use feed rates slower than 1in/min, which is 25.4mm/min. I am definitely using less than that for probing, and some times even for jogging, so if I used inches, I would like to have the ability to set even the decimals. Integers limit the use of less than 1in/min, and would only allow 1 inch intervals between values, which is simply too much. I am using metric units, so personally I don't need the decimals, but not really care that they are there since they are not disturbing.
