Trigger Outout on multiple LEDs
Postby BigAl » Thu Jun 25, 2020 10:36 am
I'm currently setting up my new configuration. I need to map an output that is triggered from two LEDs. In my case the "Spindle CW" or"Spindle CCW" should trigger an output (Spindle Cooling Fan). In the I/O Trigger screen I can only set 1 output to one LED. How can I configure a logical "OR"? Do I need to write a macro for that? Usually I prefer to use the settings screen...
Alex
BigAl
Re: Trigger Outout on multiple LEDs
Postby ger21 » Thu Jun 25, 2020 10:59 am
In this case, wouldn't two separate output triggers work?
Postby BigAl » Thu Jun 25, 2020 12:21 pm
ger21 wrote:In this case, wouldn't two separate output triggers work?
No, because then the output is flickering. This is because on of the inputs is "1" and the other "0"....
BigAl
Postby dezsoe » Thu Jun 25, 2020 12:47 pm
Create a macro, e.g. M400.txt:
exec.SetLED(exec.GetLED(50) | exec.GetLED(51), 400);
Set it as a macroloop and then LED 400 will turn on if M3 or M4 is on. Set output trigger to use LED 400. (You don't need to place the LED on the screen.)
Postby BigAl » Fri Jun 26, 2020 10:59 am
dezsoe wrote:Create a macro, e.g. M400.txt:
Thank you! This was the alternative solution I thought about...
BigAl
Users browsing this forum: Google [Bot] and 30 guests
