Appcrash UCCNC 1.2112 and 1.2113
Postby Dhobbs » Mon Jun 22, 2020 11:23 am
when I load a GCode file (seems to be any file) it is all good. but intermittently when I reload another file UCCNC displays the new code, goes to generate the tool-paths and crashes.
All machine positions are lost at next restart
(re-homing works but positions are still lost)
Windows 7 Pro with latest available updates.
Event Manager reports ---
Faulting application name: UCCNC.exe, version: 1.0.0.0, time stamp: 0x5e3845b5
Faulting module name: ntdll.dll, version: 6.1.7601.24545, time stamp: 0x5e0eb67f
Exception code: 0xc0000374
Fault offset: 0x00000000000bf262
Faulting process id: 0xa7c
Faulting application start time: 0x01d64881306937fd
Faulting application path: C:\UCCNC\UCCNC.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: 7b49da58-b474-11ea-9f25-f4ce4612a8fe
Have tried multiple screens, and profiles with no effect.
Have reloaded 1.2037 and this seems OK.
reloading 1.2112 or 1.2113 and problem back.
should I be looking further at my windows or is this a known issue?
Kind regards
Dennis Hobbs.
Dhobbs
Re: Appcrash UCCNC 1.2112 and 1.2113
Postby Dhobbs » Sun Jul 19, 2020 6:36 am
Update on this ...
After going back to 1.2111 its all rock solid. I can load as many .nc files as i like, uccnc just works beautifully.
As soon as I load 1.2112 or 1.2113 and using the same or default profiles, it loads the first .nc file and runs it no problems. But after reloading 1 or more subsequent .nc files result is appcrash and I'm back to my win7 desktop.
Kind regards
Dennis
Dhobbs
Postby Bryanecnc » Thu Feb 22, 2024 4:51 pm
Dennis,
I have this same issue. Did you figure out a solution?
Bryan
Bryanecnc
Postby cncdrive » Thu Feb 22, 2024 8:30 pm
Crashes like this always happens with computer memory problems which is in 99% of the cases are caused by OpenGL bugs in the video card drivers.
Try to update the video card drivers of your computer.
And if the drivers are already up to date then try to downgrade it to a previous version to see if it makes any difference.
If it is a PC then you can also try to use a different video card.
Users browsing this forum: Google [Bot] and 22 guests
