Fusion360 Post for ATC
Postby CL_MotoTech » Wed Apr 08, 2020 5:23 pm
I have an ATC, thus I checked "use tool changer". Cool! Looking at the gcode, this enables the tool change position (G53 X1 Y1 as specified), which I very much like. However, it also inserts M0 before each tool change. Seemingly defeating the purpose of automatic tool changes. Any chance we could get a "turn off M0) selection?
CL_MotoTech
Re: Fusion360 Post for ATC
Postby ger21 » Wed Apr 08, 2020 5:53 pm
Why not fix the incorrect post processor? Should be as simple as searching for the M0 and removing that line.
Postby CL_MotoTech » Wed Apr 08, 2020 6:14 pm
Do you mean removing the M0 insertion in the UCCNC post processor or removing the M0 in the produced code? I should have said "post processor" in my title, I suppose that could generate confusion as to what I am getting at.
I tried to adjust the post processor but wasn't successful and given that its 1000+ lines of code it's just a lot to digest for me. I'm not that good at this type of thing, though I have manipulated Mach post processors in the past. Admittedly they were like 100 lines.
I'd rather have the post processor remove the M0 than have to do it manually every time i generate g-code.
In my work flow the addition of M0 seems conflicting with the use of an ATC
CL_MotoTech
Postby ger21 » Wed Apr 08, 2020 6:15 pm
Yes, remove it from the post processor.
Can you post a copy of the post you're using?
Postby CL_MotoTech » Wed Apr 08, 2020 6:21 pm
Sure, note that "M0" is not found in the post.
This is the post as downloaded from the Fusion 360 website.
I appreciate your willingness to look at this for me!
  Copyright (C) 2012-2020 by Autodesk, Inc.
  All rights reserved.
  UCCNC post processor configuration.
  $Revision: 42683 5c1fa50acdb1bb63ef5f7fa14280f184facca587 $
  $Date: 2020-03-09 09:22:50 $
  FORKID {A976579B-D88D-49BF-BBCB-678B0F10B13A}
description = "UCCNC";
vendor = "UCCNC";
vendorUrl = "http://www.cncdrive.com/";
legal = "Copyright (C) 2012-2020 by Autodesk, Inc.";
certificationLevel = 2;
minimumRevision = 40783;
longDescription = "Generic post for machines using UCCNC control software. If you are using a fourth axis, make sure to select which axis it is mounted along. If you have an automatic tool changer you need to enable the property 'useToolChanger'. For laser cutting, set your desired power setting by using property 'laserPowerPrecentage'.";
extension = "nc";
setCodePage("ascii");
capabilities = CAPABILITY_MILLING | CAPABILITY_JET;
tolerance = spatial(0.002, MM);
minimumChordLength = spatial(0.25, MM);
minimumCircularRadius = spatial(0.01, MM);
maximumCircularRadius = spatial(1000, MM);
minimumCircularSweep = toRad(0.01);
maximumCircularSweep = toRad(90);
allowHelicalMoves = true;
allowedCircularPlanes = 1 << PLANE_XY; // allow only XY circular motion
// user-defined properties
properties = {
  writeMachine: true, // write machine
  writeTools: true, // writes the tools
  showSequenceNumbers: false, // show sequence numbers
  sequenceNumberStart: 10, // first sequence number
  sequenceNumberIncrement: 1, // increment for sequence numbers
  separateWordsWithSpace: true, // specifies that the words should be separated with a white space
  useToolChanger: false, // specifies that a tool changer is available
  toolChangePositionX: 0, // specifies the tool change position for X
  toolChangePositionY: 0, // specifies the tool change position for Y
  fourthAxisAround: "none", // specifies the fourth axis if mounted
  useSmoothing: true, // specifies to use constant velocity mode
  useParametricFeed: false, // specifies that feed should be output using parameters
  laserPowerPrecentage: 25, // set the laser power in %
  useG28: "false" // specifies the desired safe retract option
  /*referenceRun: true*/ // move to reference point first at the beginning of the program
// user-defined property definitions
propertyDefinitions = {
  writeMachine: {title:"Write machine", description:"Output the machine settings in the header of the code.", group:0, type:"boolean"},
  writeTools: {title:"Write tool list", description:"Output a tool list in the header of the code.", group:0, type:"boolean"},
  showSequenceNumbers: {title:"Use sequence numbers", description:"Use sequence numbers for each block of outputted code.", group:1, type:"boolean"},
  sequenceNumberStart: {title:"Start sequence number", description:"The number at which to start the sequence numbers.", group:1, type:"integer"},
  sequenceNumberIncrement: {title:"Sequence number increment", description:"The amount by which the sequence number is incremented by in each block.", group:1, type:"integer"},
  separateWordsWithSpace: {title:"Separate words with space", description:"Adds spaces between words if 'yes' is selected.", type:"boolean"},
  useToolChanger: {title:"Use tool changer", description:"Specifies that a tool changer is available.", type:"boolean"},
  toolChangePositionX: {title:"Tool change position X", description:"X-axis tool change position.", type:"number"},
  toolChangePositionY: {title:"Tool change position Y", description:"Y-axis tool change position.", type:"number"},
  fourthAxisAround: {title:"Fourth axis mounted along", description:"Specifies which axis the fourth axis is mounted on.", type:"enum", values:[{id:"none", title:"None"}, {id:"x", title:"Along X"}, {id:"y", title:"Along Y"}]},
  useSmoothing: {title:"Use smoothing", description:"Specifies if smoothing should be used or not.", type:"boolean"},
  useParametricFeed:  {title:"Parametric feed", description:"Specifies the feed value that should be output using a Q value.", type:"boolean"},
  laserPowerPrecentage: {title:"Laser power percentage", description:"Sets the laser power in percentage.", type:"number"},
  useG28: {
    title: "Safe Retracts",
    description: "Select your desired retract option. 'Clearance Height' retracts to the operation clearance height.",
    type: "enum",
    values:[
    //  {title:"G28", id:"true"},
      {title:"G53", id:"false"},
      {title:"Clearance Height", id:"clearanceHeight"}
var singleLineCoolant = false; // specifies to output multiple coolant codes in one line rather than in separate lines
// samples:
// {id: COOLANT_THROUGH_TOOL, on: 88, off: 89}
// {id: COOLANT_THROUGH_TOOL, on: [8, 88], off: [9, 89]}
var coolants = [
  {id: COOLANT_FLOOD, on: 8},
  {id: COOLANT_MIST, on: 7},
  {id: COOLANT_THROUGH_TOOL},
  {id: COOLANT_AIR},
  {id: COOLANT_AIR_THROUGH_TOOL},
  {id: COOLANT_SUCTION},
  {id: COOLANT_FLOOD_MIST},
  {id: COOLANT_FLOOD_THROUGH_TOOL},
  {id: COOLANT_OFF, off: 9}
var gFormat = createFormat({prefix:"G", decimals:1});
var mFormat = createFormat({prefix:"M", decimals:0});
var hFormat = createFormat({prefix:"H", decimals:0});
var qFormat = createFormat({prefix:"Q", decimals:0});
var xyzFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true});
var abcFormat = createFormat({decimals:3, forceDecimal:true, scale:DEG});
var feedFormat = createFormat({decimals:(unit == MM ? 1 : 2)});
var toolFormat = createFormat({decimals:0});
var rpmFormat = createFormat({decimals:0});
var secFormat = createFormat({decimals:3, forceDecimal:true}); // seconds - range 0.001-1000
var milliFormat = createFormat({decimals:0}); // milliseconds - range 1-?
var taperFormat = createFormat({decimals:1, scale:DEG});
var pitchFormat = createFormat({decimals:(unit == MM ? 3 : 4), forceDecimal:true});
var xOutput = createVariable({prefix:"X"}, xyzFormat);
var yOutput = createVariable({prefix:"Y"}, xyzFormat);
var zOutput = createVariable({onchange:function () {retracted = false;}, prefix:"Z"}, xyzFormat);
var aOutput = createVariable({prefix:"A"}, abcFormat);
var bOutput = createVariable({prefix:"B"}, abcFormat);
var cOutput = createVariable({prefix:"C"}, abcFormat);
var feedOutput = createVariable({prefix:"F"}, feedFormat);
var sOutput = createVariable({prefix:"S", force:true}, rpmFormat);
var pitchOutput = createVariable({prefix:"K", force:true}, pitchFormat);
// circular output
var iOutput = createReferenceVariable({prefix:"I", force:true}, xyzFormat);
var jOutput = createReferenceVariable({prefix:"J", force:true}, xyzFormat);
var kOutput = createReferenceVariable({prefix:"K", force:true}, xyzFormat);
var gMotionModal = createModal({}, gFormat); // modal group 1 // G0-G3, ...
// var gPlaneModal = createModal({onchange:function () {gMotionModal.reset();}}, gFormat); // modal group 2 // G17-19
var gAbsIncModal = createModal({}, gFormat); // modal group 3 // G90-91
var gFeedModeModal = createModal({}, gFormat); // modal group 5 // G93-94
var gUnitModal = createModal({}, gFormat); // modal group 6 // G20-22
var gCycleModal = createModal({}, gFormat); // modal group 9 // G81, ...
var gRetractModal = createModal({}, gFormat); // modal group 10 // G98-99
var WARNING_WORK_OFFSET = 0;
// fixed settings
var firstFeedParameter = 1;
// collected state
var sequenceNumber;
var currentWorkOffset;
var retracted = false; // specifies that the tool has been retracted to the safe plane
  Writes the specified block.
function writeBlock() {
  if (!formatWords(arguments)) {
    return;
  if (properties.showSequenceNumbers) {
    writeWords2("N" + sequenceNumber, arguments);
    sequenceNumber += properties.sequenceNumberIncrement;
  } else {
    writeWords(arguments);
function formatComment(text) {
  return "(" + String(text).replace(/[[\]]/g, "") + ")";
  Output a comment.
function writeComment(text) {
  writeln(formatComment(text));
function onOpen() {
  if (properties.fourthAxisAround != "none") {
    var aAxis = createAxis({coordinate:0, table:true, axis:[(properties.fourthAxisAround == "x" ? 1 : 0), (properties.fourthAxisAround == "y" ? 1 : 0), 0], cyclic:true, preference:0});
    machineConfiguration = new MachineConfiguration(aAxis);
    setMachineConfiguration(machineConfiguration);
    optimizeMachineAngles2(1); // map tip mode
  if (!machineConfiguration.isMachineCoordinate(0)) {
    aOutput.disable();
  if (!machineConfiguration.isMachineCoordinate(1)) {
    bOutput.disable();
  if (!machineConfiguration.isMachineCoordinate(2)) {
    cOutput.disable();
  if (!properties.separateWordsWithSpace) {
    setWordSeparator("");
  sequenceNumber = properties.sequenceNumberStart;
  if (programName) {
    writeComment(programName);
  if (programComment) {
    writeComment(programComment);
  // dump machine configuration
  var vendor = machineConfiguration.getVendor();
  var model = machineConfiguration.getModel();
  var description = machineConfiguration.getDescription();
  if (properties.writeMachine && (vendor || model || description)) {
    writeComment(localize("Machine"));
    if (vendor) {
      writeComment("  " + localize("vendor") + ": " + vendor);
    if (model) {
      writeComment("  " + localize("model") + ": " + model);
    if (description) {
      writeComment("  " + localize("description") + ": "  + description);
  // dump tool information
  if (properties.writeTools) {
    var zRanges = {};
    if (is3D()) {
      var numberOfSections = getNumberOfSections();
      for (var i = 0; i < numberOfSections; ++i) {
        var section = getSection(i);
        var zRange = section.getGlobalZRange();
        var tool = section.getTool();
        if (zRanges[tool.number]) {
          zRanges[tool.number].expandToRange(zRange);
        } else {
          zRanges[tool.number] = zRange;
    var tools = getToolTable();
    if (tools.getNumberOfTools() > 0) {
      for (var i = 0; i < tools.getNumberOfTools(); ++i) {
        var tool = tools.getTool(i);
        if (!tool.jetTool) {
          var comment = "T" + toolFormat.format(tool.number) + "  " +
            "D=" + xyzFormat.format(tool.diameter) + " " +
            localize("CR") + "=" + xyzFormat.format(tool.cornerRadius);
          if ((tool.taperAngle > 0) && (tool.taperAngle < Math.PI)) {
            comment += " " + localize("TAPER") + "=" + taperFormat.format(tool.taperAngle) + localize("deg");
            comment += " - " + localize("ZMIN") + "=" + xyzFormat.format(zRanges[tool.number].getMinimum());
          comment += " - " + getToolTypeName(tool.type);
          writeComment(comment);
  if ((getNumberOfSections() > 0) && (getSection(0).workOffset == 0)) {
    for (var i = 0; i < getNumberOfSections(); ++i) {
      if (getSection(i).workOffset > 0) {
        error(localize("Using multiple work offsets is not possible if the initial work offset is 0."));
        return;
  if ((properties.fourthAxisAround != "none") && !is3D()) {
    warning(localize("4th axis operations detected. Make sure that your WCS origin is placed on the rotary axis."));
  // absolute coordinates and feed per min
  writeBlock(gAbsIncModal.format(90));
  if (properties.referenceRun) {
    writeBlock(gFormat.format(28.1));
/* not supported on UCCNC
  switch (unit) {
  case IN:
    writeBlock(gUnitModal.format(20));
    break;
  case MM:
    writeBlock(gUnitModal.format(22)); // G21 is cm
    break;
function onComment(message) {
  writeComment(message);
/** Force output of X, Y, and Z. */
function forceXYZ() {
  xOutput.reset();
  yOutput.reset();
  zOutput.reset();
/** Force output of A, B, and C. */
function forceABC() {
  aOutput.reset();
  bOutput.reset();
  cOutput.reset();
/** Force output of X, Y, Z, A, B, C, and F on next output. */
function forceAny() {
  forceXYZ();
  forceABC();
  forceFeed();
function forceFeed() {
  currentFeedId = undefined;
  feedOutput.reset();
function onParameter(name, value) {
var currentWorkPlaneABC = undefined;
function forceWorkPlane() {
function setWorkPlane(abc) {
  if (!machineConfiguration.isMultiAxisConfiguration()) {
    return; // ignore
  if (!((currentWorkPlaneABC == undefined) ||
        abcFormat.areDifferent(abc.x, currentWorkPlaneABC.x) ||
        abcFormat.areDifferent(abc.y, currentWorkPlaneABC.y) ||
        abcFormat.areDifferent(abc.z, currentWorkPlaneABC.z))) {
    return; // no change
  onCommand(COMMAND_UNLOCK_MULTI_AXIS);
  if (!retracted) {
    writeRetract(Z);
  writeBlock(
    gMotionModal.format(0),
    conditional(machineConfiguration.isMachineCoordinate(0), "A" + abcFormat.format(abc.x)),
    conditional(machineConfiguration.isMachineCoordinate(1), "B" + abcFormat.format(abc.y)),
    conditional(machineConfiguration.isMachineCoordinate(2), "C" + abcFormat.format(abc.z))
  onCommand(COMMAND_LOCK_MULTI_AXIS);
  currentWorkPlaneABC = abc;
var closestABC = false; // choose closest machine angles
var currentMachineABC;
function getWorkPlaneMachineABC(workPlane) {
  var W = workPlane; // map to global frame
  var abc = machineConfiguration.getABC(W);
  if (closestABC) {
    if (currentMachineABC) {
      abc = machineConfiguration.remapToABC(abc, currentMachineABC);
    } else {
      abc = machineConfiguration.getPreferredABC(abc);
  } else {
  try {
    abc = machineConfiguration.remapABC(abc);
    currentMachineABC = abc;
  } catch (e) {
    error(
      localize("Machine angles not supported") + ":"
      + conditional(machineConfiguration.isMachineCoordinate(0), " A" + abcFormat.format(abc.x))
      + conditional(machineConfiguration.isMachineCoordinate(1), " B" + abcFormat.format(abc.y))
      + conditional(machineConfiguration.isMachineCoordinate(2), " C" + abcFormat.format(abc.z))
  var direction = machineConfiguration.getDirection(abc);
  if (!isSameDirection(direction, W.forward)) {
    error(localize("Orientation not supported."));
    return new Vector();
  if (!machineConfiguration.isABCSupported(abc)) {
    error(
      localize("Work plane is not supported") + ":"
  var tcp = false;
  if (tcp) {
    setRotation(W); // TCP mode
  } else {
    var O = machineConfiguration.getOrientation(abc);
    var R = machineConfiguration.getRemainingOrientation(abc, W);
    setRotation(R);
  return abc;
function FeedContext(id, description, feed) {
  this.id = id;
  this.description = description;
  this.feed = feed;
function getFeed(f) {
  if (activeMovements) {
    var feedContext = activeMovements[movement];
    if (feedContext != undefined) {
      if (!feedFormat.areDifferent(feedContext.feed, f)) {
        if (feedContext.id == currentFeedId) {
          return ""; // nothing has changed
        forceFeed();
        currentFeedId = feedContext.id;
        return "F#" + (firstFeedParameter + feedContext.id);
    currentFeedId = undefined; // force Q feed next time
  return feedOutput.format(f); // use feed value
function initializeActiveFeeds() {
  activeMovements = new Array();
  var movements = currentSection.getMovements();
  var id = 0;
  var activeFeeds = new Array();
  if (hasParameter("operation:tool_feedCutting")) {
    if (movements & ((1 << MOVEMENT_CUTTING) | (1 << MOVEMENT_LINK_TRANSITION) | (1 << MOVEMENT_EXTENDED))) {
      var feedContext = new FeedContext(id, localize("Cutting"), getParameter("operation:tool_feedCutting"));
      activeFeeds.push(feedContext);
      activeMovements[MOVEMENT_CUTTING] = feedContext;
      activeMovements[MOVEMENT_LINK_TRANSITION] = feedContext;
      activeMovements[MOVEMENT_EXTENDED] = feedContext;
    ++id;
    if (movements & (1 << MOVEMENT_PREDRILL)) {
      feedContext = new FeedContext(id, localize("Predrilling"), getParameter("operation:tool_feedCutting"));
      activeMovements[MOVEMENT_PREDRILL] = feedContext;
    ++id;
  if (hasParameter("operation:finishFeedrate")) {
    if (movements & (1 << MOVEMENT_FINISH_CUTTING)) {
      var feedContext = new FeedContext(id, localize("Finish"), getParameter("operation:finishFeedrate"));
      activeMovements[MOVEMENT_FINISH_CUTTING] = feedContext;
    ++id;
  } else if (hasParameter("operation:tool_feedCutting")) {
      var feedContext = new FeedContext(id, localize("Finish"), getParameter("operation:tool_feedCutting"));
    ++id;
  if (hasParameter("operation:tool_feedEntry")) {
    if (movements & (1 << MOVEMENT_LEAD_IN)) {
      var feedContext = new FeedContext(id, localize("Entry"), getParameter("operation:tool_feedEntry"));
      activeMovements[MOVEMENT_LEAD_IN] = feedContext;
    ++id;
  if (hasParameter("operation:tool_feedExit")) {
    if (movements & (1 << MOVEMENT_LEAD_OUT)) {
      var feedContext = new FeedContext(id, localize("Exit"), getParameter("operation:tool_feedExit"));
      activeMovements[MOVEMENT_LEAD_OUT] = feedContext;
    ++id;
  if (hasParameter("operation:noEngagementFeedrate")) {
    if (movements & (1 << MOVEMENT_LINK_DIRECT)) {
      var feedContext = new FeedContext(id, localize("Direct"), getParameter("operation:noEngagementFeedrate"));
      activeMovements[MOVEMENT_LINK_DIRECT] = feedContext;
    ++id;
  } else if (hasParameter("operation:tool_feedCutting") &&
             hasParameter("operation:tool_feedEntry") &&
      var feedContext = new FeedContext(id, localize("Direct"), Math.max(getParameter("operation:tool_feedCutting"), getParameter("operation:tool_feedEntry"), getParameter("operation:tool_feedExit")));
    ++id;
  if (hasParameter("operation:reducedFeedrate")) {
    if (movements & (1 << MOVEMENT_REDUCED)) {
      var feedContext = new FeedContext(id, localize("Reduced"), getParameter("operation:reducedFeedrate"));
      activeMovements[MOVEMENT_REDUCED] = feedContext;
    ++id;
  if (hasParameter("operation:tool_feedRamp")) {
    if (movements & ((1 << MOVEMENT_RAMP) | (1 << MOVEMENT_RAMP_HELIX) | (1 << MOVEMENT_RAMP_PROFILE) | (1 << MOVEMENT_RAMP_ZIG_ZAG))) {
      var feedContext = new FeedContext(id, localize("Ramping"), getParameter("operation:tool_feedRamp"));
      activeMovements[MOVEMENT_RAMP] = feedContext;
      activeMovements[MOVEMENT_RAMP_HELIX] = feedContext;
      activeMovements[MOVEMENT_RAMP_PROFILE] = feedContext;
      activeMovements[MOVEMENT_RAMP_ZIG_ZAG] = feedContext;
    ++id;
  if (hasParameter("operation:tool_feedPlunge")) {
    if (movements & (1 << MOVEMENT_PLUNGE)) {
      var feedContext = new FeedContext(id, localize("Plunge"), getParameter("operation:tool_feedPlunge"));
      activeMovements[MOVEMENT_PLUNGE] = feedContext;
    ++id;
  if (true) { // high feed
    if (movements & (1 << MOVEMENT_HIGH_FEED)) {
      var feedContext = new FeedContext(id, localize("High Feed"), this.highFeedrate);
      activeMovements[MOVEMENT_HIGH_FEED] = feedContext;
    ++id;
  for (var i = 0; i < activeFeeds.length; ++i) {
    var feedContext = activeFeeds[i];
    writeBlock("#" + (firstFeedParameter + feedContext.id) + "=" + feedFormat.format(feedContext.feed), formatComment(feedContext.description));
function isProbeOperation() {
  return hasParameter("operation-strategy") && (getParameter("operation-strategy") == "probe");
var jetMode = false;
function onSection() {
  var insertToolCall = isFirstSection() ||
    currentSection.getForceToolChange && currentSection.getForceToolChange() ||
    (tool.number != getPreviousSection().getTool().number);
  var newWorkOffset = isFirstSection() ||
    (getPreviousSection().workOffset != currentSection.workOffset); // work offset changes
  var newWorkPlane = isFirstSection() ||
    !isSameDirection(getPreviousSection().getGlobalFinalToolAxis(), currentSection.getGlobalInitialToolAxis()) ||
    (currentSection.isOptimizedForMachine() && getPreviousSection().isOptimizedForMachine() &&
      Vector.diff(getPreviousSection().getFinalToolAxisABC(), currentSection.getInitialToolAxisABC()).length > 1e-4) ||
    (!machineConfiguration.isMultiAxisConfiguration() && currentSection.isMultiAxis()) ||
    (!getPreviousSection().isMultiAxis() && currentSection.isMultiAxis() ||
      getPreviousSection().isMultiAxis() && !currentSection.isMultiAxis()); // force newWorkPlane between indexing and simultaneous operations
  jetMode = currentSection.getType() == TYPE_JET;
  if (!isFirstSection() && (currentSection.getType() != getPreviousSection().getType())) {
    writeBlock(mFormat.format(0), formatComment(localize("Pause program for changing milling/laser aggregate.")));
  if (jetMode) {
    zOutput.disable();
    sOutput.disable();
  } else {
    zOutput.enable();
    sOutput.enable();
  if (insertToolCall || newWorkOffset || newWorkPlane) {
    writeRetract(Z);
  writeln("");
  if (hasParameter("operation-comment")) {
    var comment = getParameter("operation-comment");
    if (comment) {
  if (insertToolCall && !jetMode) {
    forceWorkPlane();
    if (!isFirstSection()) {
      onCommand(COMMAND_COOLANT_OFF);
    if (properties.useToolChanger) {
      writeBlock("T" + toolFormat.format(tool.number), mFormat.format(6));
    } else {
        onCommand(COMMAND_STOP_SPINDLE);
        writeComment(localize("Move to tool change position"));
        writeBlock(gMotionModal.format(0), gFormat.format(53), "X" + xyzFormat.format(properties.toolChangePositionX), "Y" + xyzFormat.format(properties.toolChangePositionY));
        writeBlock(mFormat.format(0), formatComment(localize("Pause program for tool change")));
      writeBlock("T" + toolFormat.format(tool.number), mFormat.format(6) + " (" + getToolTypeName(tool.type) + " D=" + xyzFormat.format(tool.diameter) + (tool.description ? " " + tool.description : "") + ")");
    if (tool.comment) {
      writeComment(tool.comment);
    var showToolZMin = false;
    if (showToolZMin) {
      if (is3D()) {
        var zRange = currentSection.getGlobalZRange();
        var number = tool.number;
        for (var i = currentSection.getId() + 1; i < numberOfSections; ++i) {
          if (section.getTool().number != number) {
            break;
          zRange.expandToRange(section.getGlobalZRange());
        writeComment(localize("ZMIN") + "=" + zRange.getMinimum());
    isFirstSection() ||
    (rpmFormat.areDifferent(spindleSpeed, sOutput.getCurrent())) ||
    (tool.clockwise != getPreviousSection().getTool().clockwise)) {
    if (!jetMode) {
      if (spindleSpeed < 1) {
        error(localize("Spindle speed out of range."));
        return;
      if (spindleSpeed > 99999) {
        warning(localize("Spindle speed exceeds maximum value."));
      writeBlock(sOutput.format(spindleSpeed), mFormat.format(tool.clockwise ? 3 : 4));
    } else {
      writeBlock(mFormat.format(3)); // signal active for uccnc
  if (properties.useParametricFeed &&
      (getParameter("operation-strategy") != "drill") && // legacy
      !(currentSection.hasAnyCycle && currentSection.hasAnyCycle())) {
    if (!insertToolCall &&
        activeMovements &&
        (getCurrentSectionId() > 0) &&
        ((getPreviousSection().getPatternId() == currentSection.getPatternId()) && (currentSection.getPatternId() != 0))) {
      // use the current feeds
    } else {
      initializeActiveFeeds();
  } else {
    activeMovements = undefined;
  if (properties.useSmoothing && !jetMode) {
    if (hasParameter("operation-strategy") && (getParameter("operation-strategy") == "drill")) {
      writeBlock(gFormat.format(61));
    } else {
      writeBlock(gFormat.format(64));
  // wcs
  if (insertToolCall) { // force work offset when changing tool
    currentWorkOffset = undefined;
  var workOffset = currentSection.workOffset;
  if (workOffset == 0) {
    warningOnce(localize("Work offset has not been specified. Using G54 as WCS."), WARNING_WORK_OFFSET);
    workOffset = 1;
  if (workOffset > 0) {
    if (workOffset > 6) {
      error(localize("Work offset out of range."));
      return;
    } else {
      if (workOffset != currentWorkOffset) {
        writeBlock(gFormat.format(53 + workOffset)); // G54->G59
        currentWorkOffset = workOffset;
  forceXYZ();
  if (machineConfiguration.isMultiAxisConfiguration()) { // use 5-axis indexing for multi-axis mode
    // set working plane after datum shift
    var abc = new Vector(0, 0, 0);
    if (currentSection.isMultiAxis()) {
      forceWorkPlane();
      cancelTransformation();
      abc = currentSection.getInitialToolAxisABC();
    } else {
      abc = getWorkPlaneMachineABC(currentSection.workPlane);
    setWorkPlane(abc);
  } else { // pure 3D
    var remaining = currentSection.workPlane;
    if (!isSameDirection(remaining.forward, new Vector(0, 0, 1))) {
      error(localize("Tool orientation is not supported."));
      return;
    setRotation(remaining);
  // set coolant after we have positioned at Z
  setCoolant(tool.coolant);
  forceAny();
  var initialPosition = getFramePosition(currentSection.getInitialPosition());
  if (!retracted && !insertToolCall) {
    if (getCurrentPosition().z < initialPosition.z) {
      writeBlock(gMotionModal.format(0), zOutput.format(initialPosition.z));
  if (insertToolCall || retracted) {
    var lengthOffset = tool.lengthOffset;
    if (lengthOffset > 99) {
      error(localize("Length offset out of range."));
      return;
    if (!machineConfiguration.isHeadConfiguration()) {
      if (!jetMode) {
        writeBlock(gFormat.format(43), hFormat.format(lengthOffset));
      writeBlock(
        gAbsIncModal.format(90),
        gMotionModal.format(0), xOutput.format(initialPosition.x), yOutput.format(initialPosition.y)
    } else {
      if (!jetMode) {
      writeBlock(
        yOutput.format(initialPosition.y),
  } else {
    writeBlock(
function onPower(power) {
  var cuttingPower = 255 * (properties.laserPowerPrecentage / 100);
  if ((qFormat.getResultingValue(cuttingPower) > 255) || (qFormat.getResultingValue(cuttingPower) < 64)) {
    error(localize("Property 'laserPowerPrecentage' is out of range. Only 25% to 100% is allowed."));
    return;
  writeBlock(mFormat.format(power ? 10 : 11), conditional(power, qFormat.format(cuttingPower)));
var currentCoolantMode = COOLANT_OFF;
var coolantOff = undefined;
function setCoolant(coolant) {
  var coolantCodes = getCoolantCodes(coolant);
  if (Array.isArray(coolantCodes)) {
    if (singleLineCoolant) {
      writeBlock(coolantCodes.join(getWordSeparator()));
    } else {
      for (var c in coolantCodes) {
        writeBlock(coolantCodes[c]);
    return undefined;
  return coolantCodes;
function getCoolantCodes(coolant) {
  var multipleCoolantBlocks = new Array(); // create a formatted array to be passed into the outputted line
  if (!coolants) {
    error(localize("Coolants have not been defined."));
  if (isProbeOperation()) { // avoid coolant output for probing
    coolant = COOLANT_OFF;
  if (coolant == currentCoolantMode) {
    return undefined; // coolant is already active
  if ((coolant != COOLANT_OFF) && (currentCoolantMode != COOLANT_OFF) && (coolantOff != undefined)) {
    if (Array.isArray(coolantOff)) {
      for (var i in coolantOff) {
        multipleCoolantBlocks.push(mFormat.format(coolantOff[i]));
    } else {
      multipleCoolantBlocks.push(mFormat.format(coolantOff));
  var m;
  var coolantCodes = {};
  for (var c in coolants) { // find required coolant codes into the coolants array
    if (coolants[c].id == coolant) {
      coolantCodes.on = coolants[c].on;
      if (coolants[c].off != undefined) {
        coolantCodes.off = coolants[c].off;
        break;
      } else {
        for (var i in coolants) {
          if (coolants[i].id == COOLANT_OFF) {
            coolantCodes.off = coolants[i].off;
            break;
  if (coolant == COOLANT_OFF) {
    m = !coolantOff ? coolantCodes.off : coolantOff; // use the default coolant off command when an 'off' value is not specified
  } else {
    coolantOff = coolantCodes.off;
    m = coolantCodes.on;
  if (!m) {
    onUnsupportedCoolant(coolant);
    m = 9;
  } else {
    if (Array.isArray(m)) {
      for (var i in m) {
        multipleCoolantBlocks.push(mFormat.format(m[i]));
    } else {
      multipleCoolantBlocks.push(mFormat.format(m));
    currentCoolantMode = coolant;
    return multipleCoolantBlocks; // return the single formatted coolant value
  return undefined;
function onDwell(seconds) {
  if (seconds > 99999.999) {
    warning(localize("Dwelling time is out of range."));
  seconds = clamp(0.001, seconds, 99999.999);
  writeBlock(gFormat.format(4), "P" + milliFormat.format(seconds * 1000));
function onSpindleSpeed(spindleSpeed) {
  writeBlock(sOutput.format(spindleSpeed));
function onCycle() {
  if (jetMode) {
    error(localize("Drilling is not supported for laser cutting."));
    return;
function getCommonCycle(x, y, z, r) {
  forceXYZ();
  return [xOutput.format(x), yOutput.format(y),
    zOutput.format(z),
    (r !== undefined) ? "R" + xyzFormat.format(r) : ""];
function onCyclePoint(x, y, z) {
  if (!isSameDirection(getRotation().forward, new Vector(0, 0, 1))) {
    expandCyclePoint(x, y, z);
    return;
  var forceCycle = false;
  switch (cycleType) {
  case "tapping":
  case "left-tapping":
  case "right-tapping":
  case "tapping-with-chip-breaking":
  case "left-tapping-with-chip-breaking":
  case "right-tapping-with-chip-breaking":
    if (!isFirstCyclePoint()) {
    forceCycle = true;
  if (forceCycle || isFirstCyclePoint()) {
    repositionToCycleClearance(cycle, x, y, z);
    // return to initial Z which is clearance plane and set absolute mode
    var F = cycle.feedrate;
    var P = !cycle.dwell ? 0 : clamp(1, cycle.dwell * 1000, 99999999); // in milliseconds
    case "drilling":
      writeBlock(
        gRetractModal.format(98), gCycleModal.format(81),
        getCommonCycle(x, y, z, cycle.retract),
        feedOutput.format(F)
      break;
    case "counter-boring":
      if (P > 0) {
        writeBlock(
          gRetractModal.format(98), gCycleModal.format(82),
          "P" + milliFormat.format(P),
      } else {
        writeBlock(
      break;
    case "chip-breaking":
      if ((cycle.accumulatedDepth < cycle.depth) || (P > 0)) {
      } else {
        writeBlock(
          gRetractModal.format(98), gCycleModal.format(73),
          "Q" + xyzFormat.format(cycle.incrementalDepth),
      break;
    case "deep-drilling":
      if (P > 0) {
      } else {
        writeBlock(
          gRetractModal.format(98), gCycleModal.format(83),
      break;
    case "tapping":
      if (P > 0) {
      } else {
        writeBlock(
          gRetractModal.format(98), gCycleModal.format((tool.type == TOOL_TAP_LEFT_HAND) ? 33.2 : 33.1),
          zOutput.format(z),
          pitchOutput.format(tool.threadPitch)
        gCycleModal.reset();
      break;
      if (P > 0) {
      } else {
        writeBlock(
          gRetractModal.format(98), gCycleModal.format(33.2),
          zOutput.format(z),
      break;
      if (P > 0) {
      } else {
        writeBlock(
          gRetractModal.format(98), gCycleModal.format(33.1),
          zOutput.format(z),
      break;
      if (cycle.accumulatedDepth < cycle.depth) {
        error(localize("Accumulated pecking depth is not supported for tapping cycles with chip breaking."));
        return;
      if (P > 0) {
      } else {
        writeBlock(
          zOutput.format(z),
          pitchOutput.format(tool.threadPitch),
      break;
        return;
      if (P > 0) {
      } else {
        writeBlock(
          zOutput.format(z),
      break;
        error(localize("Accumulated pecking depth is not supported for canned tapping cycles with chip breaking."));
        return;
      if (P > 0) {
      } else {
        writeBlock(
          zOutput.format(z),
      break;
    default:
  } else {
    if (cycleExpanded) {
    } else {
      var _x = xOutput.format(x);
      var _y = yOutput.format(y);
      if (!_x && !_y) {
        xOutput.reset(); // at least one axis is required
      writeBlock(_x, _y);
  if (forceCycle) {
    sOutput.reset();
function onCycleEnd() {
  if (!cycleExpanded) {
    writeBlock(gCycleModal.format(80));
    zOutput.reset();
var pendingRadiusCompensation = -1;
function onRadiusCompensation() {
  pendingRadiusCompensation = radiusCompensation;
  error(localize("Radius compensation is not supported for UCCNC. Please change the compensation type to 'in computer' for the toolpath."));
  return;
function onRapid(_x, _y, _z) {
  var x = xOutput.format(_x);
  var y = yOutput.format(_y);
  var z = zOutput.format(_z);
  if (x || y || z) {
    if (pendingRadiusCompensation >= 0) {
      error(localize("Radius compensation mode cannot be changed at rapid traversal."));
      return;
    writeBlock(gMotionModal.format(0), x, y, z);
    forceFeed();
function onLinear(_x, _y, _z, feed) {
    // ensure that we end at desired position when compensation is turned off
    xOutput.reset();
    yOutput.reset();
  var f = getFeed(feed);
  if (x || y || z) {
      var d = tool.diameterOffset;
      switch (radiusCompensation) {
      case RADIUS_COMPENSATION_LEFT:
        writeBlock(
          gMotionModal.format(1), gFormat.format(41), x, y, z,
          conditional(properties.useToolChanger, "O" + xyzFormat.format(tool.diameter / 2)), f
        break;
      case RADIUS_COMPENSATION_RIGHT:
        writeBlock(
          gMotionModal.format(1), gFormat.format(42), x, y, z,
        break;
      default:
        writeBlock(gMotionModal.format(1), gFormat.format(40), x, y, z, f);
    } else {
      writeBlock(gMotionModal.format(1), x, y, z, f);
  } else if (f) {
    if (getNextRecord().isMotion()) { // try not to output feed without motion
      forceFeed(); // force feed on next line
    } else {
      writeBlock(gMotionModal.format(1), f);
function onRapid5D(_x, _y, _z, _a, _b, _c) {
  if (!currentSection.isOptimizedForMachine()) {
    error(localize("This post configuration has not been customized for 5-axis simultaneous toolpath."));
    return;
    return;
  var a = aOutput.format(_a);
  var b = bOutput.format(_b);
  var c = cOutput.format(_c);
  writeBlock(gMotionModal.format(0), x, y, z, a, b, c);
  forceFeed();
function onLinear5D(_x, _y, _z, _a, _b, _c, feed) {
    return;
    error(localize("Radius compensation cannot be activated/deactivated for 5-axis move."));
    return;
  if (x || y || z || a || b || c) {
    writeBlock(gMotionModal.format(1), x, y, z, a, b, c, f);
  } else if (f) {
    } else {
function onCircular(clockwise, cx, cy, cz, x, y, z, feed) {
    error(localize("Radius compensation cannot be activated/deactivated for a circular move."));
    return;
  var start = getCurrentPosition();
  if (isFullCircle()) {
    if (isHelical()) {
      linearize(tolerance);
      return;
    switch (getCircularPlane()) {
    case PLANE_XY:
      writeBlock(gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), iOutput.format(cx - start.x, 0), jOutput.format(cy - start.y, 0), getFeed(feed));
      break;
    default:
  } else {
    case PLANE_XY:
      writeBlock(gMotionModal.format(clockwise ? 2 : 3), xOutput.format(x), yOutput.format(y), zOutput.format(z), iOutput.format(cx - start.x, 0), jOutput.format(cy - start.y, 0), getFeed(feed));
      break;
    default:
var mapCommand = {
function onCommand(command) {
  switch (command) {
  case COMMAND_POWER_ON:
    return;
  case COMMAND_POWER_OFF:
    return;
  case COMMAND_STOP:
    writeBlock(mFormat.format(2));
    return;
  case COMMAND_OPTIONAL_STOP:
    writeBlock(mFormat.format(1));
    return;
  case COMMAND_COOLANT_OFF:
    setCoolant(COOLANT_OFF);
    return;
  case COMMAND_START_SPINDLE:
    onCommand(tool.clockwise ? COMMAND_SPINDLE_CLOCKWISE : COMMAND_SPINDLE_COUNTERCLOCKWISE);
    return;
  case COMMAND_SPINDLE_CLOCKWISE:
    return;
  case COMMAND_SPINDLE_COUNTERCLOCKWISE:
    writeBlock(mFormat.format(4));
    return;
  case COMMAND_STOP_SPINDLE:
    writeBlock(mFormat.format(5));
    return;
  case COMMAND_ORIENTATE_SPINDLE:
    return;
  case COMMAND_LOCK_MULTI_AXIS:
    return;
  case COMMAND_UNLOCK_MULTI_AXIS:
    return;
  case COMMAND_BREAK_CONTROL:
    return;
  case COMMAND_TOOL_MEASURE:
    return;
  var stringId = getCommandStringId(command);
  var mcode = mapCommand[stringId];
  if (mcode != undefined) {
    writeBlock(mFormat.format(mcode));
  } else {
    onUnsupportedCommand(command);
function onSectionEnd() {
  if (!isLastSection() && (getNextSection().getTool().coolant != tool.coolant)) {
  forceAny();
/** Output block to do safe retract and/or move to home position. */
function writeRetract() {
  var words = []; // store all retracted axes in an array
  var _xyzMoved = new Array(false, false, false);
  var _useG28 = false;
  if (properties.useG28 == "true") {
    _useG28 = true;
  } else if (properties.useG28 == "clearanceHeight") {
    if (!is3D()) {
      error(localize("Retract option 'Clearance Height' is not supported for multi-axis machining."));
    return; // G28 and G53 output is not desired
  if (arguments.length == 0) {
    error(localize("No axis specified for writeRetract()."));
    return;
  for (i in arguments) {
    _xyzMoved[arguments[i]] = true;
  if ((_xyzMoved[0] || _xyzMoved[1]) && !retracted) { // retract Z first before moving to X/Y home
    error(localize("Retracting in X/Y is not possible without being retracted in Z."));
    return;
  // special conditions
  if (_xyzMoved[2]) { // Z doesn't use G53
    _useG28 = true;
  // define home positions
  var _xHome;
  var _yHome;
  var _zHome;
  if (_useG28) {
    _xHome = toPreciseUnit(0, MM);
    _yHome = toPreciseUnit(0, MM);
    _zHome = toPreciseUnit(0, MM);
  } else {
    _xHome = machineConfiguration.hasHomePositionX() ? machineConfiguration.getHomePositionX() : toPreciseUnit(0, MM);
    _yHome = machineConfiguration.hasHomePositionY() ? machineConfiguration.getHomePositionY() : toPreciseUnit(0, MM);
    _zHome = machineConfiguration.getRetractPlane() != 0 ? machineConfiguration.getRetractPlane() : toPreciseUnit(0, MM);
  for (var i = 0; i < arguments.length; ++i) {
    switch (arguments[i]) {
    case X:
      words.push("X" + xyzFormat.format(_xHome));
      xOutput.reset();
      break;
    case Y:
      words.push("Y" + xyzFormat.format(_yHome));
      yOutput.reset();
      break;
    case Z:
      if (!jetMode) {
        words.push("Z" + xyzFormat.format(_zHome));
      zOutput.reset();
      retracted = true;
      break;
    default:
      error(localize("Bad axis specified for writeRetract()."));
      return;
  if (words.length > 0) {
    if (_useG28) {
      gAbsIncModal.reset();
      writeBlock(gFormat.format(28), gAbsIncModal.format(91), words);
    } else {
      writeBlock(gMotionModal.format(0), gFormat.format(53), words);
function onClose() {
  writeRetract(Z);
  setWorkPlane(new Vector(0, 0, 0)); // reset working plane
  // writeBlock(gFormat.format(28)); // retract
  writeBlock(mFormat.format(30));
  zOutput.reset();
CL_MotoTech
Postby CL_MotoTech » Wed Apr 08, 2020 6:27 pm
When I edited the PP I removed the optional stop lines (1269-1271), but then the posted code did not contain the tool change position information after this change. So again, it's just a lot to digest for me.
CL_MotoTech
Postby ger21 » Thu Apr 09, 2020 12:05 am
I think this is what you are looking for:
and:
Postby CL_MotoTech » Fri Apr 10, 2020 1:57 am
Thanks, Gerry. Let me see if I can make it work.
CL_MotoTech
Postby ger21 » Fri Apr 10, 2020 10:48 am
I would think that you want to change the M0 to M6, so you'd change the writeBlock(mFormat.format(0) to writeBlock(mFormat.format(6).
Postby CL_MotoTech » Fri Apr 10, 2020 12:55 pm
That's what I had done, but I haven't tried it out yet as my PDB is momentarily apart.
CL_MotoTech
