I do not know what the high / low state signal of the AXBB-E is but they normally have a window of say below 6 or 8 Volts being off, and above 16 to 18Volts being ON....
"There is a serial 2.2kOhm resistor on each inputs which limits the current into the
optocoupler making the optocoupler to function between
10 and 30Volts input voltage"
No. Should i? I tried one diode at output between I5- and signal but not 1 per individual.
I think i found the major problem...
My machine is all made from steel, i tried to earth it now, problem is solved, no more soft light on signal nor trigger. If i use a thin wire at first contact with chassi when spindle is ON it sparkle on wire. I meassured AC from Neutral to Chassi, when spindle is OFF = 0VAC, when spindle is ON = 100VAC (un-earthed), them earth it and spindle ON gives 0VAC and problem gone!
As my sensores are screwed on machine the source of intreference comes from that EMI
Strange fact is that start to happen yesterday, to have such voltage on chassi can it be EMI? The only wire with AC on bundle is from spindle and that one is earthed and meshed, so i suspect connections on spindle jack are lose or touching, i saw the guy who made the eletrical joints and i can say that are pretty bad joints, almost cold solder join with a big ball, but as that work i never fix it myself, will have a look at that now.
PS: A 680ohm sink resistor worked too to supress the problem.
