speed in air
speed in air
Postby BJB » Tue Mar 24, 2020 11:14 am
Wonder is anyone can help. Is it possible to reduce the speed in the air of the spindle and also is it possible to change the default jog speed from 10 to 40.
Thanks and i wish everyone is staying safe in these troubling times.
BJB
Re: speed in air
Postby ger21 » Tue Mar 24, 2020 11:53 am
The jog speed can be changed on the jog flyout panel on the left.
I don't know what you mean about the air speed in the spindle??
Re: speed in air
Postby BJB » Tue Mar 24, 2020 12:53 pm
Thanks, I know about the jog speed on the fly out, i meant is there a way to change it so it always starts at 40 instead of 10.
with regards to the air speed, i meant when carving the spindle goes from one point to another in the air off the surface, I don't know if i adjust that speed on the software Aspire or on UCCNC
Thanks for any help
BJB
Re: speed in air
Postby ger21 » Tue Mar 24, 2020 1:55 pm
There's typically no control over rpm during rapid moves, but you could edit your post processor to do it. But that would be a lot of speed changes for no real reason.
I need to look deeper into the jog speed issue, but don't have time right now.
Re: speed in air
Postby dezsoe » Tue Mar 24, 2020 2:46 pm
Jog speed: see here.
Re: speed in air
Postby BJB » Wed Mar 25, 2020 8:23 am
thanks for the jog speed info, will make the changes.
BJB
