Noob Auto Zero does not seem to set zero point.
Posted: Mon Mar 09, 2020 8:49 pm
Im making a wobbly transition from Mach3.
I am try to set the zero point on the top of my workpiece. all cuts are then -ve from that new reference.
I have setup a movable zero touchplate, the touchplate electrically seem to work just fine.
When I press the zero button, it requests I 'home the machine before probing'
Since I want to probe at that exact point, I press 'Home all' then zero again.
The tool touches off the touch plate twice as expected and retracts to a safe height.
But it does not seem to reset to the new zero point.
I'm sure Im doing something silly, any ideas?
Also, where can I set the thickness of the touchplate? In my old mach3, this thickness would be allowed for to give 0 at the surface of the stock.
thanks, J.
thanks, J.
