OK so I'm trying to migrate to UCCNC since mach3 running the plugin for AXBB keeps on randomly stopping on me. I've got everything set up fine, but the guide for setting up a probe a very unclear.
My setup is a fixed probe, using the end mill to touch to ground to give me position. Using a round bushing stuck to PCB as touch plate. After a few hours of playing around, I have managed to get it to probe Z, and when I switch to pocket it probes fine for X and Y, all if I place it in the right spot first. I got it to "save mobile probe position", but I have no idea how to set a fixed probe position, how to move it to this position, or how to set non-zero vales for this position in X Y and Z (e.g. "gauge height" didnt seem to do anything). There is a bunch of other stuff I could ask, but this seems like the best place to start.
Going up a level, what I actually need are three probe routines. In all cases go to Z machine zero, move to fixed co-ordinates, and then drop down to a fixed Z. First routine is probe Z, lift 1mm up or so, then probe for X and Y. A second routine that just probes Z. And a third routine to probe Z, but starting from a lower Z position for stubby end mills (not critical, but nice). In all three cases, X Y and Z positions need to be set, with e.g. the PCB touch surface being about 25mm underneath where my Z0 point need to be. Can I get the probe routines to do this? Or should I just give up on them, create my own M codes and give making my own buttons a go? I have all this working in Mach3 VB, so perhaps this would be the easiest, especially if there are copy/paste sections of code I could use....??
Thanks for your time...
