Unexpected results from toolpath
I began troubleshooting a problem with a Fusion toolpath that was generated using the UCCNC post for a part with a 3D profile, milled on my Bridgeport BOSS converted to servo/eth400/UCCNC. I've been running the machine for some time now and UCCNC has worked wonderfully and produced the expected results time and again. The post on the Fusion site here: https://forums.autodesk.com/t5/fusion-3 ... 505#M71606 identifies the problems and what has been done to date. I have verified that the machine is in perfect working order and after very minor compensation is free of backlash. Nevertheless, the part is being cut very poorly. The toolpath has been gone over carefully and I see no obvious reasons for the part finish that is being achieved. I've noted that the UCCNC path visually follows what the cut part looks like, but the cut part does not appear to follow the toolpath.
This video shows the tool following a scalloped path:
https://photos.app.goo.gl/GAVUoHaeyFVZPCnr6
But a review of the toolpath shows no such features. (image Capture3, attached)
The part does, however.
Here you see the scalloped finish as well as obvious gouging in the background - each of these features appears repeatably in the part.
The Fusion forum appears to feel that it's a machine problem. I'm wondering if UCCNC is accurately following the toolpath. The video above seems to support the idea that UCCNC believes it should be scalloping the path for some reason. The toolpath does not appear to follow the visual in the video or the part that gets created. I've attached the toolpath in case someone sees what I don't.
