UC300ETH-5LPT & UCBB Setup connections
Posted: Thu Oct 31, 2019 12:30 pm
Hello all,
I'm a new user and have just received my parts,
I have one or two novice questions about connecting to the UC300ETH-5LPT to the UCBB. Three cables have been sent one with parallel port end, I’m presuming I do not need this as I’m using ethernet connection to the UC300 from the computer and the connections from UC300 to the UCBB are using IDC26 cables ?
’m curious how only 8 wires in an Ethernet cable from the computer can control so many functions (inputs/outputs) compared with the old style parallel port cables that have more pins?
The second question is how to control the spindle speed on my Huanyang VFD, the 0 to 10v control is from here i presume (“IDC16 analog I/O port with 2 analog inputs and 2 analog 0-10V”) . I presume I have to purchase a IDC16 cable but where/how do I connect that to control the VFD spindle speed?
Do I require something like this pictured attached, as an earlier response from Balazs mentioned direct? , (“The UC300ETH-5LPT has direct analog 0-10V output.”) direct analogue connection so it is not through the UCBB break out board is that correct?
Mark
Mark
