ucbb powering uc300?
Postby Battwell » Fri Aug 16, 2019 4:47 pm
is 5v out on ucbb powerful/stable enough to power uc300eth?
so i only need 24v supply.
Re: ucbb powering uc300?
Postby cncdrive » Fri Aug 16, 2019 7:01 pm
You should not do that, because then you would break the isolation barrier of the UCBB breakout board.
You should use a separate 5V and 24V power supply so they can be isolated/floating to eachother on the non isolated/isolated sides.
Postby Battwell » Sat Aug 17, 2019 10:01 am
good point! il wait for the 5v supplies ive ordered then.
Postby 1.21gigawatts » Sat Aug 17, 2019 3:41 pm
I power my UC300ETH from a usb cable. Works fine.
1.21gigawatts
Postby cncdrive » Sat Aug 17, 2019 4:04 pm
You should not do that either, because then you creating a common ground of the computer and the UC300ETH which can cause noise problems.
Postby 1.21gigawatts » Sun Aug 18, 2019 2:21 pm
cncdrive wrote:You should not do that either, because then you creating a common ground of the computer and the UC300ETH which can cause noise problems.
Fair enough. I haven't seen a problem (yet), but I'm getting ready to re-arrange the furniture, and I will add a separate 5V supply for the UC300ETH.
1.21gigawatts
Postby NikolayUA24 » Sun Oct 13, 2019 7:04 am
In order not to create new topics, ask a question in this.
(UCBB dual port breakout board.
16 outputs and 18 inputs.
All I/Os optical isolated with high speed 10Mbit/sec optocouplers.)
In modern drivers, the inputs are optically isolated.With double optical isolator, it can be difficult for drivers to work.
At the entrance, optical asolation agrees need.
And why is it for the exit, a mystery to me.
It is a pity that there is no circuit on the board.
I apologize for my English. ;)
I use Google Translator.
NikolayUA24
Postby cncdrive » Tue Oct 15, 2019 10:06 pm
I don't understand your issue with the isolation?! Please explain what is exactly your problem with it?
Users browsing this forum: Bing [Bot] and 24 guests
