New and first spindle on the way!
Postby Regulator » Fri Aug 10, 2018 2:13 am
Hi Guys, so I'm finally getting a spindle and was just wondering if it can be controlled through uccnc and the ub1 300eth or do you still need the usb connection? If I still do need the usb connection does anyone have a link to the right one....Thanks Guys!!
Best Regards,
Bob
Regulator
Re: New and first spindle on the way!
Postby ger21 » Fri Aug 10, 2018 10:42 am
Yes, you can control a VFD/Spindle with relays and speed control on the UB-1.
However, if it's a Huanyang VFD, many people, myself included, have found that the rpm is not steady using analog spindle control. YMMV.
So I use Dan's Huanyang Plugin to control the rpm, but still use the UB-1 to start and stop the spindle.
Postby andrewbishop66 » Fri Aug 10, 2018 7:31 pm
got to say dans plug in is excellent
would not use any other method now
thanks Andrew
andrewbishop66
Postby Regulator » Fri Aug 10, 2018 11:19 pm
Thanks guys for the responses, which is the proper usb connector I should buy on amazon? Thanks in advance!
Best Regards,
Bob
Regulator
Postby ger21 » Sat Aug 11, 2018 1:47 am
Postby Regulator » Sun Aug 12, 2018 12:11 am
Thanks Gerry, Ordered ….lol can't wait to get it up and running hopefully I can find all the settings I need between this and cnczone forums.
Best Regard,
Bob
Regulator
Postby ger21 » Sun Aug 12, 2018 12:55 am
For anyone using the 2017 Screenset, the RPM field needs to be changed to 2451 for Dan's plugin to work correctly.
