adding atc questions about modified marco file
Posted: Fri Jun 01, 2018 5:51 pm
Please be patient Im a complete fool in programming. I search en read a few days about macro's and examples . I found in the uncnc folder the macro for m6. So far so good.
The problem is that I have my tools on a rack on the end off the table outside the range. So I added two pneumatic cilinders with sensors to open and close if need tool open , and of course close after changing tool. But how to implemend in the macro.
I dont rebuild the whole machine before everything is complete and fixed.
So I took the original macro and made some text extra with the things I think is correct.
So question 1 how to program to open en close the toolrack?
Question 2 there are two sensors on the atc sensor A checking that the relaese pin is open how to program this or skip? Sensor B checking again that toolholder is locked.
Question 3 I want a pressure sensor, so when compressed air is to low the machine is going into safety modus. Because the tool must be locked and also for colling the spindle.
Spindle used is a refurbesed colombo RC73/22
Thx again
Koen[pdf][/pdf]
