Rapid speed issue
Posted: Tue May 22, 2018 4:54 am
During the last two machining sessions I noticed that the rapid speed during linking moves was randomly higher than the maximum axis velocity settings. This was random behavior, not every time the G-code file contained a G0 command.
For example, my X&Y axis velocity settings are 200 units (inches). But at least three times the axis was commanded to move at speeds greater than that - the feed was reported as 257(IPM) in one case, and 239 in another. Most of the time it rapids right at 200, but it's gone from 210 to 275 during these events.
I can hear & see the axis moving faster than normal during these events, and I'm not losing steps. I only noticed it on longer linking moves (greater than 3" in length) as the the mill can't get up to max speed on short moves.
Does not happen - as far as I can tell - with G1 feed moves; only on X, Y, or X/Y G0 commands. Nor does it appear to happen on the Z axis.
UC400ETH, PMDX-126 BOB, Windows 8.1, UCCNC version 1.2101.
Profile attached in case that's helpful.
Any ideas what might cause this?
