Slave axis
Slave axis
Postby Dgrimm » Mon Mar 26, 2018 10:54 pm
I can’t get my “A” slave axis to work with my “Y”; anyone share their settings for this.
Dgrimm
Re: Slave axis
Postby cncdrive » Mon Mar 26, 2018 11:11 pm
It is very simple to setup a slave axis.
For your case select the A axis as slave at the bottom of the Y axis setup in axis configuration.
And ofcourse setup the port and pin numbers according to where your A axis is connected to.
And finally do not forget to press the Apply settings button to validate the settings and also the Save settings if you want the software to store the settings you made.
