Testing out how small my plasma can cut, I created small test to cut holes 0.1 in, 0.2 in, 0.3 in, and 0.4 inch. When I first ran with UCCNC it just did a single pierce at each circle start point but did not cut the circle. I turned off the torch and played with commands at MDI line using "G02 J0.1". I had made a part before with a 1 inch circle so I incremented the J value up and it started working after about .5 inch. I then tried same thing using G03 and it worked fine at all sizes using G03. I went back into sheetcam, told it to reverse direction for those cuts, and ran again and it cut all circles fine.
Is there something I'm missing? Why is it acting differently cutting in one direction versus another? Attached is test file.
