2 LAN Ports needed
2 LAN Ports needed
Postby attila0216 » Tue Feb 06, 2018 3:58 pm
Maybe someone can help me and give a good advice how to get a 2nd Lan port on my laptop. (One is for UC300eth) second is for Neuron Lite thc. I have tried today using an ethenet switch, uc300eth works, but Neuron unfortunatelly not.
attila0216
Re: 2 LAN Ports needed
Postby beefy » Tue Feb 06, 2018 6:34 pm
Try a USB-ethernet converter.
beefy
Postby cncdrive » Tue Feb 06, 2018 9:34 pm
A router will work with the UC300ETH. It can work 2 ways, with fixed IP and DHCP.
If the Neuron will work via a router depends on the device, you should ask Andrew (the manufacturer) about it, he is a member on this forum, his nick is "Shad"
Postby attila0216 » Tue Feb 13, 2018 8:42 pm
Just a quick update. It works with an ethernet switch. IP adress setings were wrong.
attila0216
