I have a small 5 VDC supply for charging phones and such.
Interesting since my last rant, I power cycled the PC several times with the BOB not connected and the motion controller initialized as it should. I then reconnected the BOB and lo and behold, it initialized as it should, that was with the stepper controller off. I turned on the stepper controller and cycled the PC again, the BOB was connected to both the Motion Controller and the Stepper Controller and the motion controller initialized as it should have.
I can't put a finger on which is the culprit, again once the BOB that is isolated comes in, perhaps that will resolve the issue. I can't explain it to a 6-year-old because nothing is consistent.
dezsoe wrote:Not enough to work, but enough to malfunction. When the USB is gets connected the UC100 will not start normally, as it is in an unknown state
That makes total sense to me, had not even given that a thought. Perhaps I should use a USB port for power to the BOB, or better yet, delay power to the BOB until the PC is up and running. I can power the Stepper Controller and the BOB via the same switch.
Robertspark wrote:Which bob are you using do you have a webpage link?
I ordered the C83 needs two independent 5 VDC sources and both ends are isolated or buffered.
