Machine Coordinates Moving Not Router
Re: Machine Coordinates Moving Not Router
Postby RsX » Fri Nov 08, 2024 6:17 pm
what kind of drives do you have?
maybe some photos/screenshot might help
RsX
Postby sebba » Fri Nov 08, 2024 6:17 pm
Reinstall UCCNC in different folder?
Input signals like estop or limit switches are working ok?
- YQWQ
sebba
Postby taawad » Fri Nov 08, 2024 6:56 pm
I have 4 stepper drivers, 3 for X1,X2,Y and all of those motors have a DM860I stepper driver, and I have a DM542T stepper driver for my Z axis.
How would I reinstall uccnc in a different folder am I just copying and pasting the files in a new folder? Not sure how I would do that an explanation would be much appreciated . My input signals of estop and limit switches are working and being showed in the controller and when I touch them on the router.
taawad
Postby RsX » Fri Nov 08, 2024 7:56 pm
If you disconnect the 2 input connector from the drivers the motors should be enabled and hard to turn. If not the problem is with the driver.
The enable is normally not connected. To disable the motor you apply voltage on the enable pins.
RsX
Postby taawad » Fri Nov 08, 2024 8:33 pm
I disconnected the 2 input connectors for 5 minutes connected then back again and still it won’t move in the software, power is being driven to the drivers.
taawad
Postby RsX » Fri Nov 08, 2024 9:00 pm
No, leave then disconnected and power on the machine. Are the motors locked with the 2 connectors disconnected?
RsX
Postby taawad » Tue Nov 12, 2024 6:08 pm
Yes the enabler is turned on and the motor is hard to move, is there a reset button or switch on these drivers to reset them?
taawad
Postby RsX » Tue Nov 12, 2024 6:31 pm
No, there is not. This means the ENA+ and ENA- are connected to the controller or to another component in the electronic box.
Can you post a photo of the controller box? Do you have a schematic?
RsX
Postby taawad » Tue Nov 12, 2024 7:24 pm
There is nothing wired into my ENA + and ENA - on my drivers that’s not how my wiring is set up, here is my controller box
taawad
Postby taawad » Tue Nov 12, 2024 7:46 pm
Here is my schematic for the wiring
taawad
