Setting not holding after restart? (Rotary axis B)
Re: Setting not holding after restart? (Rotary axis B)
Postby ger21 » Wed May 03, 2023 10:41 am
Make sure you don't have multiple hotkeys assigned to the same function for your A axis.
Postby Battwell » Wed May 03, 2023 11:53 am
set softlimits for a axis to
+9999999999999 max
-9999999999999 min
Postby Mogal » Wed May 03, 2023 4:13 pm
Hey all, opps, my bad.
I guess I did change my hotkeys to ref the B axis when it was set that way and completely forgot (pain meds!!)
So now I can manually jog the A axis properly now. (thanks Gerry for pointing me to that again)
The soft limit issue remains however. (only affects the A axis movement)
- I have made the work around as Battwell suggests and that has corrected the issue.
- I really dislike fudging the system like this though.
Mogal
Postby ger21 » Wed May 03, 2023 5:06 pm
There's really no other way to do it, if you want it to be able to rotate in both directions.
Users browsing this forum: Bing [Bot], naijin and 31 guests
