Probing problems
Re: Probing problems
Postby dhb9mm@gmail.com » Fri Apr 08, 2022 11:09 am
i forgot to give you the probe version. it is 1.3.2.0 by Szentkerszly Csaba.
dhb9mm@gmail.com
Postby dezsoe » Fri Apr 08, 2022 11:41 am
Yes, I know, that's me. :)
OK, so your problem is that you don't have the Fine distance set. The movements are as follows:
- probe the selected axis in the given direction in max. P1 units, Fast feed speed
- retract the axis with Fine distance
- probe again with Fine feed speed
- retract to start position
- zero if needed
So, set the Fine distance. And also, on the Setup page select Greater Z is safer in G17: this will tell the program that the safe Z zone is up.
Postby dhb9mm@gmail.com » Sat Apr 09, 2022 12:21 am
thanks that worked. can you look at my profile, and see if you can tell me why when i home my axis. none of them back off and do a fine or slow homing?
dhb9mm@gmail.com
Postby dezsoe » Sat Apr 09, 2022 9:19 am
As Gerry already wrote you there's no second homing. Use a higher speed towards the sensor, so it will not take a long time to get there and a low speed to come off the sensor. The homing will be precise, don't worry.
Postby MikeM » Mon Apr 11, 2022 10:11 am
dezsoe wrote:Yes, I know, that's me. :)
- zero if needed
This is very useful info.
Thank you!
MikeM
Users browsing this forum: No registered users and 44 guests
