Y and a slave axis jog and move correctly but only y homes
Re: Y and a slave axis jog and move correctly but only y h
Postby dezsoe » Wed Nov 03, 2021 11:45 pm
Never do that! Make a shortcut on the desktop and after UCCNC.exe write /p profilename to start your profile. (Since 1.2114 when you switch profile the whole program restarts, so you can switch profile.)
Postby Mark Kraus » Fri Nov 05, 2021 9:41 pm
Does anyone have an idea ? With a slaved y it really hard to use rhe machine without homing. Is it possibly a hardware issue, although I cannot see how since everything works including jog and g code . I just replaced some broken screws in the rails because of the gantry twisting. Any help would be greatly appreciated.
Mark Kraus
Postby Mark Kraus » Sat Nov 06, 2021 3:38 am
Does anyone have any ideas? Any help would be greatly appreciated.
Mark Kraus
Postby Mark Kraus » Tue Nov 16, 2021 2:16 am
We switched to the default profile that loads on start up. Now everything works fine. I know it sounds dumb but how do I save all my settings and rename this default profile that works?
Mark Kraus
Postby dezsoe » Tue Nov 16, 2021 6:29 am
Go to UCCNC\Profiles directory. Make a copy of "Default.pro" and rename it to e.g. "Sample.pro". Create a new directory and rename it to "Macro_Sample". On your desktop make a copy of the UCCNC shortcut. Rename it as you like, e.g. "Sample UCCNC". Right-click and edit properties. After UCCNC.exe write " /p Sample" to start your profile.
Users browsing this forum: No registered users and 30 guests
