The dotted horizontal white line is the zero Z line. There are lot of things above that.
cncdrive wrote:Dwell is wait or pause which can be turned on for M3, M5, M5, M7, M8, M9. The dwell also works with G4 Pxx.
When you set that checkbox then the time for all dwells is measured in seconds instead of milliseconds.
If you want the dwell times in seconds then you just set that checkbox and if you need less than one second, e.g. 100msec for the M7 then just write 0.1 in the delay box, because 0.1seconds equals 100msec.
ger21 wrote:I just ran into this issue a few days ago with another user, and the M3 delay.
When I created the screen, I simply copied the text from the default screen, which showed the "ms". This is obviously not correct, if Dwell in Seconds is selected.
The next version of the screen will not have the "ms" labels.
