Jagged Arcs/Circles
Jagged Arcs/Circles
Postby tedris » Wed Mar 02, 2022 10:39 am
Hi there,
i got a problem with my CNC running an ETH300 5LPT.
Circles/Arcs or non linear (combination of X and Y) movements seem to be very rough.
I use Fusion as a CAM software and tried the following so far:
in UCCNC:
Constant Velocity Mode ON/OFF
Acceleration of X and Y up to 1800mm\s2
in Fusion:
Smoothing enabled: Tolerance and Smoothing both at 0.05mm at the moment (to generate less lines of code and starve the controller)
Deactivated IJK mode in the Postprocessor so i only get polylines
Nothing seem to help with the issue, see the picture of a Part i routed.
tedris
Re: Jagged Arcs/Circles
Postby ger21 » Wed Mar 02, 2022 12:02 pm
In UCCNC, turn CV on, and increase the error tolerance settings.
However, it look to me like there may be some mechanical issues, as the cut is not very uniform.
Postby tedris » Wed Mar 02, 2022 12:16 pm
The Constant Velocity is on as i wrote in my OP.
I cant confirm nor deny if there is a mechanical issue. To me it seems as if not but i wanted to search for software issues first, since i read a lot about uccnc problems with arcs and such.
I have no issues with linear cutting moves (for example when i cut out a square contour as a test). The problems only occure when both axis are moving at the same time.
tedris
Postby ger21 » Wed Mar 02, 2022 1:43 pm
You need to adjust the CV settings, until it cuts the arcs properly.
Postby tedris » Wed Mar 02, 2022 2:55 pm
I dont really get what you are saying.
I only see a checkbox for constant velocity, nothing can be adjusted.
Maybe i am missing something?
Would you recommend letting UCCNC using G2/G3 Gcode or would you recommend only polylines instead?
tedris
Postby hmnijp » Wed Mar 02, 2022 3:25 pm
tedris wrote:I dont really get what you are saying.
There are no serious problems with the arcs. There is a problem with the fact that people do not understand how to configure the CV for their tasks.
These settings, they affect the operation of the CV. you can read about them in the manual. You can try to install the same. If you do not need serious accuracy, you can increase the error value.
or here is a little explanation and practice of use.
viewtopic.php?p=26223#p26223
I am using fusion360. I recommend using arcs, but the postprocessor setting "minimum chord length" = 0.1-0.2mm. - this will remove many small arcs.
hmnijp
Postby tedris » Thu Mar 03, 2022 7:59 am
I set all the CV settings as in your picture except for arc radius tolerance and linear error max, which i set to 0.1.
See picture fo results
1: My previous result (1500mm/min Feedrate)
2: same G-Code with polylines with new CV settings (1500mm/min Feedrate)
3: G-Code with IJK (G2/G3) new CV settings (1500mm/min Feedrate)
4: G-Code with IJK (G2/G3) new CV settings (500mm/min Feedrate)
Samples 1 2 and 3 look very much identical in real life. Sample 4 looks better than the other samples, though far from acceptable for me...Still jagged edges.
The feedrates at 1500mm/min is the calculated and recommended feed from sorotec (acrylic 1 tooth cutting tool)
Im i am not mistaked the fact that lower feedrate shows a better result is telling me that either my accel is too high or i have an mechanical issue. Or am i wrong here?
tedris
Postby ger21 » Thu Mar 03, 2022 12:30 pm
Try setting it to a higher value, 0.2, or even 0.5, and see if the result is different.
Postby fixebr » Thu Mar 03, 2022 5:05 pm
Can you post the G-Code file with which you get this result?
fixebr
Postby tedris » Thu Mar 03, 2022 7:17 pm
(F1-Rim-Acryleinsatz)
(T30  D=6. CR=0. - ZMIN=0. - Schaftfraser)
G90
G53 G0 Z0.
(2D-Kontur1)
T30 M6 (Schaftfraser D=6. Sorotec Acryl 1Schneider)
S24000 M3
G64
G54
M8
G43 H30
G0 X3.633 Y12.8
Z18.
Z8.
G1 Z6.1 F500
Y12.624 Z5.676 F500
Y12.2 Z5.5
Y11.6
G3 X4.233 Y11. I0.6 J0.
G1 X49.5 Z3.919 F500
G2 X56.5 Y4. Z3.535 I0. J-7.
X49.5 Y-3. Z3.151 I-7. J0.
G1 X4. Z1.562
G2 X-3. Y4. Z1.178 I0. J7.
X4. Y11. Z0.794 I7. J0.
G1 X26.75 Z0.
X49.5 F1536
G2 X56.5 Y4. I0. J-7.
X49.5 Y-3. I-7. J0.
G1 X4.
G2 X-3. Y4. I0. J7.
X4. Y11. I7. J0.
G1 X26.75
G3 X27.35 Y11.6 I0. J0.6
G1 Y12.2
Y12.624 Z0.176
Y12.8 Z0.6
G0 Z18.
M9
M5
G53 G0 Z0.
M30
Nothing fancy really
tedris
Users browsing this forum: No registered users and 50 guests
