I have been troubleshooting this for 20+ hours. My machine is unusable and I am at a loss what to do.
I am having an issue with homing and spindle and the symptoms are drastically different if I run 1.2048 or 1.2106
Homing Issue:
1.2048- My machine will not home. When I home any axis it it moves toward the NPN NC limit backs off the limit and goes into an error state that you can't get the software out of without closing it down and reloading it.
1.2106 - Machine homes as expected on all Axis. Basically a non-issue and all limits act as expected. I don't know what is different in this version but it works fine.
Spindle Issue:
I am running my spindle as a step/direction spindle. If I run my spindle from the VFD the machine operates normally so I don't think it is noise. I am running Igus chainflex shielded cable so noise should be contained.
1.2048 - as soon as I enable the spindle or issue an M3 Sxxxx command it says Limit Switch Triggered and nothing happens.
1.2106 - This is super weird. If I install the software and load my cnc profile I can enable the spindle and issue M3 SXXXX commands and the spindle works awesome. I can go from 10 RPMS to 24k no probelm. When I tell it to run 18k it shows 303hz on the VFD wich is perfect. I can do this for as long as I want and jog the machine while it is happening. If I shut the spindle down, when I go to re-enable it is says Limit Switch Triggered. If i close down the software and open it again same thing.. Limit switch triggered. If I reinstall the software the spindle works fine again... once..... and then same problem.
If 1.2106 would work without needing to reinstall the software each time I would just use that version but I am at a loss of what to do.
Jeremy
