Mach3 errors
Mach3 errors
Postby Tim_DGE » Mon Apr 09, 2018 5:51 am
Hi All,
I have begun setting up the UC300ETH-5LPT. I got a parallel breakout board to which I’ll connect the UC300. Now I did all the network settings and there doesn’t seem to be a problem, it pinged the network correctly and everything. I also installed the Mach3 plugin. However, when I start up Mach3, it detects the plugin, I select the UC300, then it gives the first error: (See attached “Error1” jpeg)
After this it asks if I want to replace the firmware. When I select “Yes” it gives the following: (See “Error2” jpeg).
Can you help?
I have not connected any components to the boards yet (motors, switches, etc).
Regards,
Tim
Tim_DGE
Re: Mach3 errors
Postby Tim_DGE » Mon Apr 09, 2018 6:48 am
I seem to have solved the problem. The UCx00setup had not properly installed. Once I did that, I redid the network settings, and when opening Mach3, firmware successfully installed.
Tim_DGE
Users browsing this forum: No registered users and 38 guests
