Wire Output to an Input
Re: Wire Output to an Input
Postby cncdrive » Tue Feb 27, 2018 3:56 pm
If doing it on the motion controller. I mean a motion controller output to the same motion controller input, you can do that safely, because the output is TTL output and the input also accepts TTL voltage levels, and if it is the same motion controller then the I/Os are referenced to the same 0Volts (ground) point.
Users browsing this forum: Bing [Bot] and 18 guests
