Dead at startup.
Dead at startup.
Postby Sorendk » Mon Nov 06, 2017 6:25 pm
Hello absolutly new to Uc cnc. I have installed the program and added lisence key, but when i start the program it dies.. it does not not start up the right way and it is not in demo mode. What can be the problem.
Sorendk
Re: Dead at startup.
Postby dezsoe » Mon Nov 06, 2017 8:36 pm
Could you explain what do you mean by "it dies"? Maybe, could you make screenshot(s)? What version with what controller? I'll try to help you if I see your problem.
Postby ger21 » Mon Nov 06, 2017 8:40 pm
And what version of Windows are you using?
Postby Sorendk » Mon Nov 06, 2017 8:49 pm
I can only install it in demo mode. Now i have tryed to reinstall it and insert the lisene key but i does not detektor it. Before it did detektor it but then it “died” stall after start up, mening it just shows blank screen. I use Uc 100 on a Windows 7 64 bit pc. 128 gb Samsung ssd and 4 gb ram. 2.4 GHz semi old machine but every thing Else is running ok ?
Sorendk
Postby dezsoe » Mon Nov 06, 2017 9:48 pm
OK. You can only install in demo mode, that is normal. Does it start normally in demo mode? Can you see "UC100 CNC Motion Controller" in Windows device manager? If you run UCCNC\Util\UCxxx_utility.exe and press Scan button, does it show your UC100? (Exit UCCNC before you start UCxxx_utility!)
Users browsing this forum: No registered users and 29 guests
