G68 coordinate rotation
Postby shad » Sat Jun 03, 2017 7:24 am
Hello Balazs!
I am use this future for plate alignment.
Operator set two points on the plate, then plugin calculate rotation angle and execute for example "G68X0Y0R3" code.
I am notice, that if the current XY position is not X0Y0, UCCNC make coordinate rotation and gantry move to the zero position (any time this position out from plate and in the Active code DRO I see for example |G68X-7.5Y59.5R7.2|).
Usually G68 just rotate coordinates, but not make any moves.
May be I am doing something wrong?
Please explain :)
Thank you!
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
http://neuroncnc.com/
shad
Re: G68 coordinate rotation
Postby dezsoe » Sat Jun 03, 2017 9:07 am
If you run "G68X0Y0R3" then it will move, because G68 works with A and B instead of X and Y. So, you programmed a "G0X0Y0" and a "G68R3". Try "G68A0B0R3".
Postby cncdrive » Sat Jun 03, 2017 11:09 am
Hi Andrew,
Yes, the issue is that you using X and Y, but the parameters of the G68 are A and B, so the X and Y in your code is interpreted separately as a movement with the actul modal 1, that is why a movement happens with your code.
Postby shad » Sat Jun 03, 2017 3:45 pm
Oh, I am understand :oops:
Thank you, It's worked fine.
-- Andrew
UC400ETH
UC300ETH-5LPT
NEURON Lite THC
shad
Users browsing this forum: Bing [Bot] and 18 guests
