Laser control issue
Laser control issue
Postby docschrock » Thu Jan 23, 2025 1:48 am
I'm trying to set up a laser on my DIY router, uc400eth controller. I have my laser powered with 12v and the pwm set to pin 14 from the uc400eth. I can turn the laser on with the spindle button and control the intensity with the S slider.
However, when I try to use the laser engraving plugin, is only fires the laser at low intensity and does not change. Is there something I'm missing?
docschrock
Re: Laser control issue
Postby cncdrive » Thu Jan 23, 2025 10:55 pm
The laser plugin is using the Laser output pin not the spindle PWM is the issue.
You find it in the I/O settings.
Postby docschrock » Sat Jan 25, 2025 3:09 pm
Thanks, that worked.
Now I'm trying to figure out how to have the laser burn back and forth on my Y axis instead of my X axis. Is there a way to do that? Or would I have to reconfigure my machine and swap the axes?
docschrock
