AXBB-E pin doesn't works
Postby Mathieu 33 » Tue Oct 22, 2024 7:25 am
I am trying to connect the pin number 1" Isolated Outputs" as described in the drawing for piloting ground relay. It doesn't works.
Should we set something on the software to get this fonction?
Thank you in advance
Mathieu 33
Re: AXBB-E pin doesn't works
Postby cncdrive » Tue Oct 22, 2024 9:07 pm
Output 1. is a dedicated charge pump output, that output works only if configured as charge pump output in the UCCNC software.
You could use any other outputs.
Users browsing this forum: Google [Bot] and 8 guests
