Add 3rd Probe 3 possible?
Postby mr_cg » Fri Apr 12, 2024 11:26 pm
Hello!
I have already setup Probe 1 (Z-Probe) and Probe 2 (3d-probe) and want to add Probe 3 for tool length measurements.
Unfortunately i can only find two PIN/PORTS to be used for Probe configuration.
Is there any possibility to add 3rd Probe 3 which is connected to other PIN/PORT?
Thanks for help and support.
Br
Chris
mr_cg
Re: Add 3rd Probe 3 possible?
Postby Delco » Sat Apr 13, 2024 1:00 am
you can use multiple probes on the one input IF they are triggered the same , I have one pin configured for normally open and the other for normally closed , so at present I have a touch sensor and a probe on the one input.
You could also use a input trigger to activate a probe input when the input is triggered.
Delco
Postby mr_cg » Sat Apr 13, 2024 2:38 pm
Delco wrote:You could also use a input trigger to activate a probe input when the input is triggered.
This goes exactly into the direction how i wanted to do it but i do not know how.
How to use a input trigger to activate a probe input?
mr_cg
Postby cncdrive » Sun Apr 14, 2024 4:53 pm
You can connect normally closed (NC) probes in series to one input and you can connect normally open (NO) probes in parallel to a single input.
If you have both types then you can use 2 separate inputs.
