I have a Chinese GDZ-80 spindle (it has no sensor) and a pretty decent Delta MS300 VFD. I'd like to be able to calibrate the spindle in such the way that the RPM under no load is exactly as what was set. Currently, I'm using analog voltage output of AXBB-E and the voltage corresponds to the setpoint, so the issue is definitely on the VFD/spindle side.
In Mach 3 there was a way you could do measurements e.g. with 1000 rpm step and save a table that had set rpm against measured (actual) rpm in linearity.dat file that was used to proportionally compensate for the error. Is there a similar functionality or plugin in UCCNC? I couldn't find anything relevant in the forum and again - I am using a handheld laser tachometer. The spindle does not have a sensor I could use in the VFD to have a PID loop.
