Help with Spindle Configuration
Postby pjaromin » Fri Jan 12, 2024 3:57 pm
I have my VFD wired similarly to the diagram in the AXBB-E manual. The A01 analog output controls the frequency perfectly. However the isolated output sends a PWM signal instead of a clean "on/off" when M3 is turned on/off. This results in the spindle not starting at lower frequencies.
When I tried using the "Direction" config it appears to toggle with M4 not M3. What am I missing here???
pjaromin
Re: Help with Spindle Configuration
Postby cncdrive » Sat Jan 13, 2024 3:52 pm
If the isolated output send a PWM signal then that output is configured for spindle PWM probably.
Check your configuration.
You should configure that output as spindle relay and not spindle pwm pin.
Users browsing this forum: klikn, Majestic-12 [Bot] and 19 guests
