by dezsoe » Thu Dec 29, 2022 8:07 pm
Hi Vincenzo,
There's no problem with your IP settings. Also, you may use normal cable, the network card made in the last min. 10 years will change to cross automatically. However, try to find the correct driver for the card. As I see you have a USB network card, so check the driver, check USB sleep options. I don't know what kind of PC you have, but if possible, use the USB ports on the back which are on the motherboard and not on the front panel. If you have a USB hub then use only powered hub. Also check the 5V supply for the AXBB, it must be 5V, if it goes too low then the network may become instable.
