issue with macro restart
Postby girogiri » Wed Aug 31, 2022 9:22 am
Hi All,
I'd like to ask support to know why this M3 macro is not working.
in particular the line that restart the G-code execution
exec.Callbutton(128);
is not executed if this code is executed first
if(!AS3.Getbuttonstate(ATC_SEALED_BUTTON)){
        exec.Callbutton(ATC_SEALED_BUTTON);
   while(exec.Ismacrorunning(ATC_SEALED_BUTTON) > 1 ){Thread.Sleep(20);}
thanks
Giorgio
M3.txt
(12.61 KiB) Downloaded 190 times
girogiri
Re: issue with macro restart
Postby girogiri » Fri Sep 02, 2022 7:35 am
no replies?
attached is the "ATC_SEALED_BUTTON" macro ( aka M20044.txt) called in the IF cycle described in previous post.
It works with no issues, I'm attaching it to better understand the whole process
this is the relevant part of it:
if(Convert.ToBoolean(exec.Readkey("UserCheckboxes", Convert.ToString(ENABLE_ATC_CHECKBOX), "False"))){
   if(!AS3.GetLED(ATC_LIFE_LED)){
      exec.Informplugin("Messages.dll", (object)"#Ok: Raffreddamento ATC (M20044)|ATC Offline.");
   else if(!SendDataBin(ATC,1, !my_status, ATC_WRITE_SEALED_BIT)){
      exec.Informplugin("Messages.dll", (object)"#Ok: Raffreddamento ATC (M20044)|Invio comando sealed fallito.");
   else{
      AS3.Switchbutton(!my_status, ATC_SEALED_BUTTON);
else{
   exec.Informplugin("Messages.dll", (object)"Ok: Raffreddamento ATC (M20044)|ATC non abilitato.");
I don't see reasons why this code should block the
statement
thanks
Giorgio
M20044.txt
(7.67 KiB) Downloaded 182 times
girogiri
Users browsing this forum: No registered users and 26 guests
