GOTO ZERO Problem
GOTO ZERO Problem
Postby ljr8378 » Sat Jul 30, 2022 7:30 pm
I would like all axes to "GOTO ZERO". When I hit the GOTO ZERO button, the machine and work coordinates in the UCCNC software goto zero and I hear the stepper motors activate briefly. The trouble is that the stepper motors do not position the cutter to the zero (or home) location. I am attaching a screen shot of the X-axis setup. Could I get some feed back.
Lauren
ljr8378
Re: GOTO ZERO Problem
Postby ger21 » Sat Jul 30, 2022 9:44 pm
Sounds like your steppers are stalling. Try decreasing the velocity and acceleration about 20%.
Postby Dazp1976 » Sat Jul 30, 2022 11:24 pm
Goto zero runs at your rapid speed.
How far out of position does your cutting go when you rapid position from one point to the next? .
Like Ger21.
Reduce your speeds.
Dazp1976
Postby ljr8378 » Sun Jul 31, 2022 2:44 am
Reducing the acceleration seems to have fixed the problem. I am sure the issue arose from when I calibrated the software to my mill. I went from 200 steps/unit to 20670 steps per unit. I did not change any of the acceleration values, which was obviously a problem in hide sight. There doesn't seem to be a lot of information on the setup values in the manual. Is there another document or YouTube video that I could get more detailed/additional information?
Lauren
ljr8378
Users browsing this forum: Bing [Bot] and 46 guests
