Internal viariables
Internal viariables
Postby terastios » Sat Jul 23, 2022 1:01 pm
Hello
I am going to use some internal variables for parametric programing
Is there any way to put a textfield input on the screen to point at the variables?
#1=300
#2=500
#3=3
#4=0
#5=0
#10=0
M7
M98 P1 L10
M9
M30
O1
#4=#10
#10=#2+#4
G01 X#1 C#10 F10000
#4=#10
#10=#4+#3
G01 C#10 F500
M99
on the code above before running I would like to see the content
or even better to be able to change the numbers of variable #1 and #2
terastios
Re: Internal viariables
Postby terastios » Sun Jul 24, 2022 6:27 pm
I found a workaround with a macro
string strVar1;
string strVar2;
string strVar3;
 if (AS3.Getbuttonstate(144)) // if machine is in reset no point in trying to update the variables
   else //MACHINE NOT IN RESET / E-STOP, UPDATE VALUES
   if (!exec.IsMoving())  // no point updating on the fly as the frontend does not actually know where the machine tool actually is because of the comms buffer, and macroloop timing.  These values are not updated in macroB during motion either.
        strVar1 = AS3.Getfield(5001);
        exec.Setvar(Convert.ToDouble(strVar1), 1 );
        strVar2 = AS3.Getfield(5002);
        exec.Setvar(Convert.ToDouble(strVar2), 2 );
        strVar3 = AS3.Getfield(5003);
        exec.Setvar(Convert.ToDouble(strVar3), 3 );
      MessageBox.Show(exec.mainform,"Lenth: " + strVar1 + Environment.NewLine +
                             "Turns: " + strVar2 + Environment.NewLine +
                             "Steps: " + strVar3
The starting code was taken from a post in here
https://www.forum.cncdrive.com/viewtopic.php?f=15&t=1735
I made 3 fields , I insert the values and then I run the macro
but I am still interested if it is possible a field to point right to the variable
terastios
Postby ger21 » Mon Jul 25, 2022 10:51 am
Make the macro a macro loop that runs all the time.
Postby terastios » Mon Jul 25, 2022 5:22 pm
ger21 wrote:Make the macro a macro loop that runs all the time.
Thanks for the input
Is there any documentation how to make a pop up window to input the variables?
or even an example that has something similar that I can read to understand?
I took a quick look in the forum but I didn't find anything
terastios
Postby eabrust » Tue Jul 26, 2022 12:22 am
Hi terastios,
I do my macros in VB, and I've had luck w/ the following to load a variable from an input box prompt.
The following would be a numbered macro file that I call from a specific GCode file at the file start, so that I am prompted for a 'diameter' before the GCode runs, and it is loaded into var #1.
#VB
dim newvar as double
dim newinput as string
newinput = microsoft.visualbasic.inputbox("value", "Enter new value", var1) ' I believe you will call microsoft.visualbasic.inputbox in C# also
if newinput <> "" then
try
   newvar = convert.todouble(newinput)
catch  'Something went wrong, exit
   'exit/bail out!
   exec.code("m5")
   exec.code("m0")
   exec.code("M30")
   exit sub
end try
   messagebox.show(newvar) ' Verify the value w/ a report back.
else  'Nothing entered, quit!
   'exit/bail out!
   exec.code("m5")
   exec.code("m0")
   exec.code("M30")
   exit sub
end if
exec.setvar( newvar, 1)
hope it helps a little. This reference verifies to use the VB input box for C# use: https://stackoverflow.com/questions/97097/what-is-the-c-sharp-version-of-vb-nets-inputdialog
Postby terastios » Tue Jul 26, 2022 1:36 pm
eabrust wrote:
Hi terastios,
#VB
try
   'exit/bail out!
   exec.code("m5")
   exec.code("m0")
   exec.code("M30")
   exit sub
end try
   'exit/bail out!
   exec.code("m5")
   exec.code("m0")
   exec.code("M30")
   exit sub
end if
Thank you very much
This is helpful
I am going to run some tests with your code as a starting point
:D :D
terastios
Postby terastios » Tue Jul 26, 2022 2:10 pm
Hi eabrust
This worked fine for me
the only change i made is in this line
to
newinput = microsoft.visualbasic.inputbox("value", "Enter new value",  exec.Getvar(1)) ' I believe you will call microsoft.visualbasic.inputbox in C# also
var1 was not acceptable and the macro couldnt run
terastios
Postby eabrust » Tue Jul 26, 2022 11:44 pm
Hi terastios
glad it worked for you and you found my paste error.
I trimmed down a larger macro file for you, and forgot to paste in (or rather accidentally deleted) the variable initialization line, which was just:
dim var1 as double = exec.getvar(1)
good luck and have fun!
