Reduction ratio of spindle
Postby CADdy » Sat Jul 23, 2022 2:55 pm
Hi all,
I have a tool change spindle that has a reduction ratio of 1:0.583. So when the drive motor is turning at 10000 rpm, the milling spindle is doing 5830 rpm. Where can I set this ratio in UCCNC? If I set the speed for a tool in CAM to e.g. 7000 rpm, the motor should get a default of 12000 rpm. But it is wrong to set this value in the CAM, because all defaults for feed, cutting speed, etc. would not be correct. So UCCNC should calculate the correct preset for the motor from the 7000 rpm from the CAM.
Or am I wrong?
Peter
CADdy
Re: Reduction ratio of spindle
Postby Dazp1976 » Sat Jul 23, 2022 6:12 pm
There is a section for spindle 'Pulley'. You would set your ratio as if it were a pulley I believe.
Dazp1976
Postby CADdy » Sat Jul 23, 2022 9:31 pm
Ah, thank you so much. I've found it in the handbook.
Peter
CADdy
Postby CADdy » Tue Jul 26, 2022 4:24 pm
are these settings ok?
Pulley Settings1.png (7.13 KiB) Viewed 2353 times
This results in a motor speed range of 6000 to 24000 rpm.
Is the M215 P1 command mandatory to activate Pulley 1, although I have set the check mark in the settings?
I then get this window and have to click it away by hand:
Pulley Settings3.png (1.59 KiB) Viewed 2353 times
Pulley Settings2.png (21.21 KiB) Viewed 2353 times
Peter
CADdy
