by Mcasey » Thu May 20, 2021 7:47 pm
Hi, I'm using proximity switches on the limits of a machine and we are having an issue where the signal is not constant, the hard limit is flashing on and off when the limit is made, the problem is that when you press the override limits the signal might break for a moment and then the override limits turns off before you actually move the axis and the process starts all over again, my question is can the override limit be made active until it is pressed again to turn off, I don't want it to auto turn off.
